Do they make Oxygen Sensor extenders?
  • Thread starter Thread starter N8Miller
  • Start date Start date Mar 27, 2004
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Mar 27, 2004
  • Mar 27, 2004
i just added my BBK long tubes, but the o2 sensor bungs are way further down that they were in the H pipe. Do they make an extender peice that fits in between the sensor and the plug? or should i just splice the wires and make them longer? on stuff like this i would just rather have 1 peice because that computer sh1t is complicated and really dont wanna be messing with that stuff.
thanks
88mustangGT
298
  • Mar 27, 2004
well what i didt was just tace back the harnus and youll have to cut the oil sending cencer but that can be reatached when you are done. but i am 100% you dont need to spend a dime to have your o2s reach the long tubes. there is plenty of length. also if you did buy extenders i heard they can cause false readings. hope this helps.
88stangmangt
2,332
Stafford,VA
Mar 27, 2004
  • Mar 27, 2004
i have bbks and they are **** i hate them.
OLDJUNK93
77
kansas
Mar 27, 2004
  • Mar 27, 2004
you have to extend them, they are not long enough. i spliced in some wires on mine but i wish i would have bought the extenders. you can get them at just about any mustang performance web site like 5.0 resto or brothers performance.
88mustangGT
298
  • Mar 28, 2004
extending or splicing can cause false readings so i would just go with re routing them.
NeQX
904
Infront Of You, NY
Mar 28, 2004
  • Mar 28, 2004
I got BBK, and I re-routed mine
Rick 91GT
Mustang Master
95
99
PA
Mar 28, 2004
  • Mar 28, 2004
Yep...just pull the wires back from the harness to get them to where you need to. If you plan to buy new O2's the Bosch models are also available with a longer pigtail.
If you soilder the connection correctly and use the same grade wire you can extend the O2's....just need to do it correctly.
P
PRO50SC
1,012
Olney, Maryland
Mar 28, 2004
  • Mar 28, 2004
There are aftermarket companies that make o2 harness extenders. Check the 5.0 mags or stang websites.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
