Do you shift at redline or no?
  • Thread starter Thread starter Shadow
  • Start date Start date Apr 14, 2004
Shadow
165
  • Apr 14, 2004
Im new to the whole v8 thing since i get my stang on saturday. But i have a 5.0 5 speed. When doing a 1/4 mile run where would you shift?
NYC LSC
626
Staten Island, NYC
Apr 14, 2004
  • Apr 14, 2004
Stock? No more than 5200, IMO.
Starscream88
1,277
Park Ridge NJ
Apr 14, 2004
  • Apr 14, 2004
V8's are not really designed to be revved the pi$$ out of,
Thats why they achieve there highest Tourque numbers pretty low down and the max HP levels are usually around 4600 to 5200,
Theres your guidelines,
You bend a pushrod, Your on your own,
You have been warned
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Apr 14, 2004
  • Apr 14, 2004
stock motor 5000-5200...anything higher your reving higher & actually making less HP (typically). Besides depending on how weak the stock valve springs are you may float the valves earlier than that.On the dyno when my car was basically stock it was all done by 4900 rpm
BlackFox5.0
3,514
Massachusetts
Apr 14, 2004
  • Apr 14, 2004
I always thought on a stock motor around 5500rpms is where you should shift.
I shift around 5500, I have a rev limiter at 6000
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Apr 14, 2004
  • Apr 14, 2004
my shift light goes off at 5k. the car likes it alot and stays for the most part right in the power band
T_5.0_N'works
260
Texas
Apr 14, 2004
  • Apr 14, 2004
Someone tell me my optimum shift point. I have a 92 Coupe. All that is done is H pipe, bullet mufflers, GT40 intake, ecam, timming, free mods, air filter, no silencer. I was told to shift around 5600rpm, correct? I've been shifting at 5900-6k rpm.
90_Red_LX
668
Asheboro, NC
Apr 14, 2004
  • Apr 14, 2004
I usually shift at 5500, but after hearing the valves could float, hell I'm droppin to 5k lol....can't lose by daily driver.
NYC LSC
626
Staten Island, NYC
Apr 14, 2004
  • Apr 14, 2004
If you had a set of heads other than stock on there, I'd shift at 59-6000rpm. The stock heads, regardless of what else you've got done are holding you back from making more power up that high.
BlackFox5.0
3,514
Massachusetts
Apr 14, 2004
#10
  • Apr 14, 2004
  • #10
The only way to find out is to go to a dyno.
millhouse
1,985
Simpsonville, SC
Apr 14, 2004
#11
  • Apr 14, 2004
  • #11
I currently shift around 5600 rpm due to my intake.
Back when I was stock, I was shifting at 5600 rpm due to the crappy 2.73 rear gears. The rpm drop was so great with those gears, so if I shifted any lower I would be dropping out of my best power range.
Another thing to keep in mind is the inconsistancy of stock ford tach's. They have been notoriously off from car to car. Using a tech calculator and speed I found mine to be pretty accurate at most rpms. It's usually doesnt get way off until you get into the upper rpm range.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Apr 14, 2004
#12
  • Apr 14, 2004
  • #12
lights set for 5500... seems to be pretty good for me, but I never fooled around with it! This is also on a Autometer Tach, not the stocker!
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Apr 14, 2004
#13
  • Apr 14, 2004
  • #13
Yeah my stock tach was off by 600 RPM @ 5400RPM ...IE was really 5400RPM but stocker was reading 6k
T_5.0_N'works
260
Texas
Apr 14, 2004
#14
  • Apr 14, 2004
  • #14
Yeah I know, when I got the car it had the e cam in there already, I wish the cam was stock. I'am just trying to pull out the best time I can for this car mostly on free mods, since I'am building a 357 185 AFR for the coupe.
Going to try 5600 RPM shifts tonight, see where that gets me, I'll have it dynoed pretty soon.(Have Autometer SportComp Gauge )
90_Red_LX
668
Asheboro, NC
Apr 14, 2004
#15
  • Apr 14, 2004
  • #15
What would you use to check the tach accuracy? Hopefully not a lot of $$
Gixxer750
789
Saint John NB, Canada
Apr 14, 2004
#16
  • Apr 14, 2004
  • #16
Wow I must be granny shiftting
Shift light is set at 4900
V
v8only
2,378
22
49
Apr 14, 2004
#17
  • Apr 14, 2004
  • #17
You'll know if you've revved it too far, you'll feel the power drop off.
I personally never hit the red line, and rarely go past the yellow. I don't have a big budget, and my engine's worth more to me than any race.
90_Red_LX
668
Asheboro, NC
Apr 14, 2004
#18
  • Apr 14, 2004
  • #18
I hit red once, to test the power, didn't feel too potent shortly after yellow, but usually I get it up to about 5500 with 2.73's.
M
Matts89LX5.0
1,314
Long Island, NY
Apr 14, 2004
#19
  • Apr 14, 2004
  • #19
well the e cam pretty much peaks and mostly stops making power after about 4500 rpms but with the gt40 i would just shift around 5500 rpms
-someone correct me if i'm wrong about the e cam but i'm pretty sure after my friend showed me a dyno sheet of his with the cam.
Matt
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
