  • SN95 4.6L Mustang Tech
Does anyone know...
  • Thread starter Thread starter JerseyTrueBlue
  • Start date Start date Mar 9, 2009
J
JerseyTrueBlue
56
New Jersey
Mar 9, 2009
  • Mar 9, 2009
I would like to do some mods to the stang but I'm not sure about some things. Basically I would just like to know if anyone has had any experience, problems, or tips with these upgrades or similar ones. The things I'm thinking of getting are Coil on spark plugs, larger brake discs for all wheels (any sugestions?), Summit or bbk pulleys, fidanza flywheel. Thanks for any suggestions or tips. Also does anyone know what hardware I would need to do a basic 2v pi head swap? Just wanna make sure I got everything I need before I go ahead and put em on and find myself in a bad way. Thanks again.
tag4car
Birmingham AL
Mar 10, 2009
  • Mar 10, 2009
Brakes- Cobra or Mach One
Pulleys- Steeda, Nobody recommends BBK pulleys!!
What year are we working with here??
Tim2002GT
635
Tulsa, Oklahoma
Mar 10, 2009
  • Mar 10, 2009
+1 on the Cobra/Mach 1/Bullitt brakes and on the Steeda pullies. Stay away from the piggyback BBK pullies. As for PI swap info, check out this thread...
http://forums.stangnet.com/717166-pi-headswap-write-up.html
Silverstang02GT
60
Ft. Myers FL
Mar 10, 2009
  • Mar 10, 2009
I have Granatelli coils on my car and the Steeda pulleys
3,287
24
69
Broke
Mar 10, 2009
  • Mar 10, 2009
Try having a quick search for "first mods" or something like that. Dont waste your money on a flywheel, dont buy any brand pulleys EXCEPT Steeda.
If its a non-PI car then headswap and gears are best choices. If its a PI car, gears and a tuner (Eg XCAL3) are you best first mods in my opinion. Then some exhaust work to make your car sound like a mustang. Lowering is great for improving handling and imrpoving looks.
J
JerseyTrueBlue
56
New Jersey
Mar 11, 2009
  • Mar 11, 2009
Thanks for the help a little late now but the car is a 2001 GT. Heads are stock however mods include CAI, Throttle Body, Plenum and 3.73's. I will be sure to get those steeda pulleys. Anyone know a good place to buy?
trinity_gt
3,125
81
99
Canada
Mar 11, 2009
  • Mar 11, 2009
Do some research on your car first before planning a modification roadmap. For instance, you asked about a "basic 2v pi head swap" but your car, being a 99+, will already have the PI heads and manifold from the factory.
If you enter the mod game without basic knowledge of the car, you're going to get hosed by unscrupulous vendors and spend money on useless things that have terrible, if not negative, bang/buck ratios.
NO BRAKES
129
Avon Lake, Ohio
Mar 11, 2009
  • Mar 11, 2009
the cobra brake kit is awesome. i got a score on one for 400. thats calipers, rotors, pads, spindles, and all brackets and bolts. im one of the lucky ones for that cheap. i needed everything because of old 4lug fox stuff.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Mar 11, 2009
  • Mar 11, 2009
Ok dude since you already have some decent mods, i would go with the pulleys(like you said you plan on), subframe connectors, and suspension. Also if you don't already have a tuner that would be a good idea. Also those Cobra brakes have a great reputation.
blksq10psi
114
PHILLY
Mar 13, 2009
#10
  • Mar 13, 2009
  • #10
you got pi heads man it sounds like its bone stock dont waste your money on a brake kit yet get a set of good pads for now untill u need a brake kit here are your basic bang for buck mods... off road x pipe , 3.73 gears, cat back , underdrive pullies, timing adjuster, (im outside philly i have the u/d pullies and timing adj. if u wanna buy there from steeda) i short throw shifter i love my tri-ax, cold air intake , 75mm t-body upper intake plenum, here is a good start and most of these you can do in your driveway and they usually dont cost more than 200$ new make sure you do your homework on your car before you go out ordering parts
blksq10psi
114
PHILLY
Mar 13, 2009
#11
  • Mar 13, 2009
  • #11
i also reccomend the weapon X cop but you dont really benifit from them untill you have a poweradder otherwise i feel you can spent the 300-400$ on something else and if its an automatic toy can get a shift kit but i dont know anything about them (i like banging gears)
badge placement
  • 65er
  • Jun 8, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 8, 2026
65er
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
Ignition Question
  • WantAn88GT
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
WantAn88GT
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
