does this pattern look ok?
  • Thread starter Thread starter project67
  • Start date Start date Jan 21, 2010
1 of 2 Next Last
P
project67
116
  • Jan 21, 2010
its my first time doing a gear swap and i was wondering if this pattern would be ok or not. this is with the factory pinion shim and side shims. thanks for your opinions in advance!
Chrome_Rust
530
Findlay, Ohio
Jan 21, 2010
  • Jan 21, 2010
No pic bro....
P
project67
116
  • Jan 21, 2010
whoops! forgot the pic
http://www.stangnet.com/mustang-forums/members/project67-albums-stuff-picture4863-picture-034.jpg
Chrome_Rust
530
Findlay, Ohio
Jan 21, 2010
  • Jan 21, 2010
looks to be a little far out on the teeth. you want it in the center as much as you can. you need to add another shim to the pinion, or a thicker one.
F
FastStang91LX
31
Minnesota
Jan 21, 2010
  • Jan 21, 2010
Just a tad less on the pinion wouldn't hurt
P
project67
116
  • Jan 21, 2010
yeah thats what i was thinking, just didnt want to pull it back out. oh well.
Chrome_Rust
530
Findlay, Ohio
Jan 22, 2010
  • Jan 22, 2010
Less would move the contact patch farther from the center. He needs to move the contact area closer to the center. Maybe you are looking at it backwards. Not trying to bust balls...
Warbird19
742
Washington, Federal Way
Jan 22, 2010
  • Jan 22, 2010
you really should buy a dial indicator, there cheap and gears will make tons of noise or even break if now setup correctly. Pinion depth is also extreamly important. I would paint about 4-5 teeth and see what your looking at. Looks like you should start by taking 5 thousands off the pinon shim. remember that when you do that your going to need a new chrush sleeve and everything. Backlash needs to be close to 10-15 thousands before you can accuratly check pinion depth. Its a pain in the ass without a master housing depth tool.
P
project67
116
  • Jan 23, 2010
getting closer. i removed the factory shims and installed a .044" shim (thicker than the factory shims) and it looks better. now i will check backlash and yes i will be using a dial indicator.
http://www.stangnet.com/mustang-forums/members/project67-albums-stuff-picture4871-picture-038.jpg
in the pic you can see drive side and coast side, they are a little closer to the toe side of the ring gear but they are both the same, indicating correct pinion depth, right?
now to adjust the backlash and viola i should be good.
Chrome_Rust
530
Findlay, Ohio
Jan 23, 2010
#10
  • Jan 23, 2010
  • #10
Looks good! Looks like the gears in my 93, and there are 15k miles on that since I built it.
94GTCoupe
1,412
92
79
CA
Jan 23, 2010
#11
  • Jan 23, 2010
  • #11
looks good.
chrome rust was right on.
P
project67
116
#12
  • Jan 23, 2010
  • #12
nice. i love the day after a gear swap-its like i picked up 50 rwhp
going from 2.73 to 3.73 with my mods should be fun.
thanks for the help guys
btw to remove the nasty yellow stuff, is brake clean ok?
Tanus
847
A to the Z
Jan 24, 2010
#13
  • Jan 24, 2010
  • #13
brake clean is fine, a little of the yellow left on the teeth wont hurt anything. dont forget to add the friction modifier to the fluid.
if you have a big cam the dif between 2.73 and 3.73 is HUGE!!!!!!!!!
P
project67
116
#14
  • Jan 24, 2010
  • #14
my cam is pretty much stock. its from a 93 cobra, with the crane 1.7's
hopefully it will feel faster. i want to run mid to high 12's
Tanus
847
A to the Z
Jan 24, 2010
#15
  • Jan 24, 2010
  • #15
should be 12s, but you can bumop the cam up a size if your not at 12s
P
project67
116
#16
  • Jan 24, 2010
  • #16
yeah, once i pass ca smog, i'm swapping a tfs 1 or b-cam.
Tanus
847
A to the Z
Jan 24, 2010
#17
  • Jan 24, 2010
  • #17
I passed emissions no problem with the X cam, which is pretty big. az is pretty strict on the smog too. I think we have the same requirments as ca
P
project67
116
#18
  • Jan 24, 2010
  • #18
^^^thats insane! you're car must run really well because the x cam is pretty stout.
oh well, maybe ill just go ahead and do the swap now and see what happens. come smog time.
know of anyone getting rid of a tfs1 of b cam?
Tanus
847
A to the Z
Jan 25, 2010
#19
  • Jan 25, 2010
  • #19
I just sold a B cam on ebay like 2 weeks ago, Im looking for a TFS stage 2 to swap for the Z cam I have now
oh and the trick for passing emissions is retarding the timming a ton, like 4 BTDC
P
project67
116
#20
  • Jan 25, 2010
  • #20
oh. well in ca, part of the test is to check timing.
damn!
1 of 2 Next Last
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
Looking for a high-res photo or scan of Rotunda EEC-IV Overlay #17 or #23
  • Smokinjoe 33
  • Jul 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2026
Praetorious
P
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
