Dont Know How To Explain Really
Micheal Nadeau
258
32
49
Savannah, GA
Driving down the road in 4th or 5th, it feels like someone is tugging on the car. Speed doesnt really make a difference. Not present @ WOT. Last 6 months, new TPS, IAC, ECT, MSD Coil, MSD Cap and rotor, NGK plugs Ford Racing Wires. Motor is an Explorer block with GT40P heads, gasket matched explorer upper and lower, pro products 76 mm TB, 24 # injectors, matching mass air, F303. If its been covered, lemme know and I will try to find it again. Didnt see anything, probably because I dont know what to call it.
Define the feeling of "tugging" on the car. Are you saying it seems to lack power, as though its dragging, or do you mean to say it's feel's jerky?
What RPM does this occur at? Below 1,500RPM?
What's your ignition timing set at? Jerky cruise can often be caused by too much advance in your ignition timing. Try dialling it back down to the stock 10-degree's and see if it goes away.
Are you throwing any computer codes? Could be a speed sensor issue?
I went through and redid the vacuum lines on the intake. Removed some that went nowhere and replaced old ones. I don't have a base line to go off of with vacuum. I run between 12 - 13 in/hg at idle. I don't want to dismiss anyone's opinion, and if some could through in their vacuum numbers that have cams, could help. I feel like this may be something else. Cruising at 60 mph, every :45 sec to say 1:15 it cuts out for a millisecond.
Did you try dropping the timing yet? I know 14* isn't much(that's where mines at) but I'd try it. Especially if running less than 93 oct gas. FMS wires also have been known to be an issue.
Cylinder balance test: use this to find dead or weak cylinders:
Revised 25 March 2012 to add necessity allowing the KOEO tests to finish before starting the engine and the need for a properly functioning IAB/IAC to run the cylinder balance test.
The computer has a cylinder balance test that helps locate cylinders with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
If you have idle or IAC/IAB problems and the engine will not idle on its own without mechanically adjusting the base idle speed above 625-750 RPM, this test will fail with random cylinders pointed out every time it runs. The IAC/IAB must be capable of controlling the engine speed to run in the 1400-1600 RPM range. Playing with the base idle speed by adjusting it upwards will not work, the computer has to be able to control the engine speed using the IAC/IAB.
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Let it finish the Key On Engine Off (KOEO) code dump. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. Remember to keep the clutch pedal (5 speed) depressed to the floor during the test. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent/loan. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
PM me for details on how to build your own blow down type compression tester.
I have heard from a few sources that the FMS 9MM wires are hit or miss. This has been going on since before I did the plugs and wires. I just bought a compression tester from Snap - On, intend to compression test the motor later today. I have not adjusted the timing down any. My timing light went on strike so now I need to find a replacement.
Compression tested the motor. Cyl 1 - 170, Cyl 2 - 180, Cyl 3 - 170, Cyl 4 - 175, Cyl 5 - 170, Cyl 6 - 175, Cyl 7 - 170, Cyl 8 - 175. All my plugs appear as if I am running lean, running 42 psi?? Its got a 255 Walbro. I will drop the timing down to 12 degrees tomorrow at work and see what that does. I had it on cruise for about 8 miles @ 60 mph earlier and didn't notice anything today. I also had the wife and kids in the car.
