Door hinge repair kits
  • Thread starter Thread starter Darrin
  • Start date Start date Feb 25, 2008
Darrin
184
Cocoa, Florida
Feb 25, 2008
  • Feb 25, 2008
I have a really worn out door hinge but, I can't get a set of hinges right now. Does anyone have a supplier to get a door hinge repair kit that has a 14mm outside diameter bushings. The biggest the parts store has is a 13mm from a Camaro door kit. It's just too small.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 25, 2008
  • Feb 25, 2008
wow 5.0resto doesnt even carry them. im deff subscribing to this.
Darrin
184
Cocoa, Florida
Feb 25, 2008
  • Feb 25, 2008
I bought their "oversized" repair kit and it isn't big enough. Had the body shop look for a bigger set and the biggest they carried was 13mm for a Camaro. I just don't know where to look. Tried all the parts stores.
Fast63
717
  • Feb 26, 2008
What you talking about?
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-23204-KIT 1&comp=LRS
50resto is where I bought my hinge pins, and there is the link. When I bought mine, they sold them per door, and now they sell them for both doors in the same package. My pins are still working great.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Feb 26, 2008
  • Feb 26, 2008
well damn. i looked all over that site for those. thanks man.
nisreo
178
  • Feb 26, 2008
This will fix the sagging problem correct?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 26, 2008
  • Feb 26, 2008
Hinge pin & bushing kits are available at many auto parts stores. Or see http://www.texasmustang.com/ or http://www.mustang-unl.com/. Usually less than $8 for the kit with one pin & 2 bushings.
Th hard part is to get the old pin out. Some were spot welded in, others were hammered so that the end mushroomed. Either way, it takes a grinder or cutter bit in a drill or Dremel tool to cut the pin or grind off the weld. Once it is off, tap the pin out with a hammer. Only remove one pin at a time so that you don't have the full weight of the door to manage. I highly recommend that you have a helper standing by to hold the door.
Once the old pin is out, lower the door and tap out the old bushings. Put the new bushings in and have the helper lift the door in place so that you can slide the new pin in. It may have to go in differently from the way it came out. That's OK, as long as you put the cotter pin in the hinge pin.
OOOPS!!!The important thing to remember is that the hinge pin isn't supposed to move once you are finished. If it does, then you will end up like me - the pin moved, it wore the door hinge instead of the replaceable bushings. Now in order to fix it right, I have to remove the whole thing again and drill out the hinge to the same size as the bushing and use 2 sets of bushings in each hinge rather than one set.
The fix for the OOOPS was very time consuming and if you aren't up to some very interesting machine work, do it right so you won't have to do it again. I fixed the OOOPS but I had $43 worth of drill bit and specialized reamer plus pulling the fender off to fix it.
Darrin
184
Cocoa, Florida
Feb 26, 2008
  • Feb 26, 2008
I found the repair kit from 50resto, I bought them. I even bought the oversized ones they offered. Too small. Mine is worn pretty well. I looked in the parts stores and the biggest I found had an outside diameter of 13mm where the grooves are. This is just barely too small. So I figured if I can find them in a 14mm I'd be ok.
Fast63
717
  • Feb 26, 2008
Sometimes companies make it hard to find stuff on their site, especially through the search engine function They even updated their site, but I think it's harder to navigate now! Oh well
1993SSP
1,194
Ky
Feb 27, 2008
#10
  • Feb 27, 2008
  • #10
Darrin, which hinges would you need?? I have 4 old doors that were removed from a 1991 model and a 1993 model. I'd hook you up reasonably, let me know, PM me
2000xp8
SN Certified Technician
Aug 8, 2003
8,063
1,647
194
NJ
Feb 27, 2008
#11
  • Feb 27, 2008
  • #11
By me, these pin kits are in nearly every store, even pepboys in the "help" section, (you know the ones with the red packaging of odd stuff).
Mine came from carquest, and i've been told autozone has them.
Cost me like $8 per door.
Darrin
184
Cocoa, Florida
Feb 27, 2008
#12
  • Feb 27, 2008
  • #12
Problem solved. I got to talking with the body guy and asked if could weld real good. He said yes and I offered that he should weld the hole, grind it down and then re-drill the hole. He thought it was such a great ides he did it for free to see if it would work. It did! PERFECT... 1993ssp, thanks for the offer, I might still take you up on it for a project car I'll be doing in a few months.
nisreo
178
#13
  • Jun 3, 2008
  • #13
im going to throw a quick tack weld on the bushing for now because my bushing hole is worn out too.
Fast63
717
#14
  • Jun 3, 2008
  • #14
You should tack weld the bushing on anyway because that will keep it from rotating inside the hole of the door. Only the pin should be free to rotate for longevity sake.
LiquidGT
368
Near STL hell
Jun 3, 2008
#15
  • Jun 3, 2008
  • #15
The bushing looks like its copper or brass and I thought that welds didnt stick to those metals, but I guess it would be a good way to ''build'' some metal around the worn hole.
ram360
2,162
Pennsylvania
Jun 4, 2008
#16
  • Jun 4, 2008
  • #16
I don't see how the bushing hole wore out? I can see the bushings being worn but not the holes. First time I ever heard of that.
Fast63
717
#17
  • Jun 4, 2008
  • #17
I think bushing holes wear out when people put their fat *** weight on the door, putting stress on it. It's not as common as the bushing itself wearing out, but it does happen.
Hinge Roller repair kit
  • Rdub6
  • Aug 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 5, 2026
gkomo
R
85 T-Top doors hard to close... Just how it is?
  • rwordenjr
  • Dec 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 7, 2024
rwordenjr
R
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
A
Scott rod strut tower repair kit
  • Alfred L Lutz
  • Feb 15, 2025
1996 - 2004 SN95 Mustang -General/Talk- Feb 16, 2025
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
