Door lock noises!..?
MUSTANGJOE
Silver Stanger
1,644
17
59
Hi guys,
I'm having a problem with my door locks. They work just fine but the passenger side door lock makes a noise every time I unlock/lock the door. Kinda like an annoying wistle or something, like the actuators needs greasing up or something! Is this a sign of them about to fail? :shrug:
MUSTANGJOE said:
Hi guys,
My 91 convertible has been doing that since I got it almost 4 years ago. Most likely the actuator.
Squirt a little WD-40 in the key hole and the back of the lock cylinder (after door panel removal). The arm to the solinoid goes to the lock cylinder that turns and squeeks after a few years. If you don get the back, the cyl wil come apart just like my 95 vert's did.
I believe moisture is what really kills these -- all the bad ones I've seen have torn rubber boots. So if it happened after a car wash, I'd say chances are you're right. Not a bad idea to luve the linkage anyway, but I wouldn't get too attached to this actuator.
