Door lock switch and turn signals
Makdaddymac
323
orlando
hey all out of nowhere my unlock/lock door switch does nothing, both sides worked and today for no reason neither do anything, completely dead, i was wondering where to start with this, how come both switches on drivers and pas. door just quit...
also as far as my tun signals, they do not flash, not a bulb thing just no flashing, i have to manually keep flicking the switch when i drive it, i read in the hayes manual that its the flasher; which is fine but while i was making this thread i was wondering if anyone know of any other issues about non flashing turn signals:shrug:
Number#1 check fuses, Number #2 swap the two flashers to make a easier check as to whether the flasher is out or if it is a different issue altogether. Now my Hazard flasher was wired to the backside ofthe fuse block, and my street flasher was zip tied to my steering column. So make sure you find both.
Good luck. My bet is a fuse (If both went out at the same time) and just the flasher
highly unlikey both switches dumped out at the same time,:rolleyes:
i cannot locate the power windows/door lock fuse is this the fuse panle near the column( on the left and lower side of the column)? where are both flashers located? i think one is this fuse panel near the column but the other is near the ignition switch??
pwindows work perfect both sides....:shrug: both door lcoks are dead not even clicking? i would suspect one side to not work it would be the swtich but both switches at the same time is too weird.... could this be correltated to my radio not working. the PO did a hack job into the original stereo harness and for some reason the head unit cut out, if i take it out and reset it it will come back on? i thought it was the head unit but this leads to suspect a short somewhere....
