is ther any diff in the door panels for a coupe/hatch vs a conv one? i know the mirrors on the ouside of the door are diff. but are the panels the same?
stykthyn said:the dew wipes are longer on the vert. save your old ones or buy new ones if you are going to swap panels.
Check the location of the handles. They might be slightly different.ryan218 said:as to not start a new thread.
will door panels form a 87-93 vert work on a 83-86vert?
PJB said:Check the location of the handles. They might be slightly different.
Also some of the mounting holes might be different and need to be drilled out.
Im not sure thats the case but its a possibility.
you have to get the arm rest and all the harnes for the powerwindows, but it all bolts up for the most partryan218 said:as to not start a new thread.
billison said:you have to get the arm rest and all the harnes for the power windows, but it all bolts up for the most part
billison said:you can find manual window panels easy, and the cutouts for the power locks are on the back of the panel you just have to cut out with a knife
PJB said:Just look for a base model 4 banger coupe. Theyre most likely to have manual windows and locks.
Well then look for panels with that combination.ryan218 said:my car has manual windows but has electric locks
PJB said:Well then look for panels with that combination.
