Door Panels
Um i just reinstalled my door panels yesterday, I was lookin at how to do this though. Just get 2 drill bits. The one drill needs to be the size of the head of the plastic pushin clip and the other drill bits needs to be the size of the stud on the pushin clip. Then you should be able to take a razor blade and cut out a section between the holes that lets the pushin clip slide over once you get it in the masonite board. Get what i mean? I just decided to use the panels i had and run them till i can find some decent take off's on EBAY!
-AJ
-AJ
Yea i think im gonna buy used ones also, its too much damn work the 50resto ones.
I reupolstered my door panels.. it is actually really easy.. just pull the staples... fold up the material... take the crappy old cardboard out and replace with 1/8th piece of wood from home depot or rona.. just trace the holes.. Then pop rivet the new piece on... I bought about 15 dollars worth of black vinyl.. and just covered the old material... get a staple gun with short staples... and your off... there is a couple detailed areas that were a bit different to do.. Instead of the carpet at the bottom I just used vinyl.. If you lye a piece of vinyl upside down... and get a thin strip of steel like a ruler.. and pop rivit on the piece of vinyl through the steel... with the fabric lying up over the top of the panel.. now after pop riveting that on you can fold the fabric down and it will make a nice straight folded line... double sided tape is helpful.. and special fabric glue.. My panels look really nice.... only thing I need to replace is the door arm rest.. painting it doesn't look too good.
Anythony, seems like alot of work man..
I could just buy the 50resto's ones for $120.00 or whatever they are and just rivet that metal type piece and cut the holes for the armrest and the door handle and pop out piece for speaker grille and im set...
how hard is it to put the weatherstripping at the top of the door panel..
don't need the map pockets.. they look shiitty anyways..
look at this guys..
came out really good.
