Door Panels
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Nov 2, 2006
First Prev 2 of 2
ChromdOutDubs
268
Tavares, Florida
Dec 11, 2006
#21
  • Dec 11, 2006
  • #21
Um i just reinstalled my door panels yesterday, I was lookin at how to do this though. Just get 2 drill bits. The one drill needs to be the size of the head of the plastic pushin clip and the other drill bits needs to be the size of the stud on the pushin clip. Then you should be able to take a razor blade and cut out a section between the holes that lets the pushin clip slide over once you get it in the masonite board. Get what i mean? I just decided to use the panels i had and run them till i can find some decent take off's on EBAY!
-AJ
savegoodautonfg
1,085
#22
  • Apr 26, 2007
  • #22
-AJ
Yea i think im gonna buy used ones also, its too much damn work the 50resto ones.
AnthonyR23
661
Ontario
Apr 26, 2007
#23
  • Apr 26, 2007
  • #23
I reupolstered my door panels.. it is actually really easy.. just pull the staples... fold up the material... take the crappy old cardboard out and replace with 1/8th piece of wood from home depot or rona.. just trace the holes.. Then pop rivet the new piece on... I bought about 15 dollars worth of black vinyl.. and just covered the old material... get a staple gun with short staples... and your off... there is a couple detailed areas that were a bit different to do.. Instead of the carpet at the bottom I just used vinyl.. If you lye a piece of vinyl upside down... and get a thin strip of steel like a ruler.. and pop rivit on the piece of vinyl through the steel... with the fabric lying up over the top of the panel.. now after pop riveting that on you can fold the fabric down and it will make a nice straight folded line... double sided tape is helpful.. and special fabric glue.. My panels look really nice.... only thing I need to replace is the door arm rest.. painting it doesn't look too good.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Apr 26, 2007
#24
  • Apr 26, 2007
  • #24
Anyone happen to have pictures of the door panels from 50resto on an actually car?
savegoodautonfg
1,085
#25
  • Apr 26, 2007
  • #25
some guy had this on a thread.
actually look pretty good.
http://i60.photobucket.com/albums/h18/liljuicedcoupe/HPIM0001.jpg
savegoodautonfg
1,085
#26
  • Apr 26, 2007
  • #26
Anythony, seems like alot of work man..
I could just buy the 50resto's ones for $120.00 or whatever they are and just rivet that metal type piece and cut the holes for the armrest and the door handle and pop out piece for speaker grille and im set...
how hard is it to put the weatherstripping at the top of the door panel..
don't need the map pockets.. they look shiitty anyways..
look at this guys..
came out really good.
First Prev 2 of 2
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
R
Door Panels
  • RGP413
  • Aug 29, 2026
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
D
rear upper seat trim panel for 1995 ford mustang.
  • dustinbowman95gt
  • Aug 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
dustinbowman95gt
D
Door wiring, Unknown plug
  • TripleYellow
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
gkomo
