  • SN95 4.6L Mustang Tech
door pannel
  • Thread starter Thread starter Aggie 08
  • Start date Start date Apr 18, 2006
A
Aggie 08
30
on campus at A&M Galveston
Apr 18, 2006
  • Apr 18, 2006
I'm trying to remove my door pannel to put in new speakers, and am having the hardest time getting the pannel off. I only found one screw, and the rest seem to be just snaps. So far all I can do is get the top loose and thats it, so if anyone has any experince with a 97' door pannel, it would be really appreciated.
96BlueStangGT
38
Southern Indiana
Apr 18, 2006
  • Apr 18, 2006
First take the plastic clip off the lower front of the door panel with a flathead screwdriver. Then remove the plastic piece around the door lock and window switches. Do that by taking the screwdriver and put it in the place at the top and pry it out, then at the top of the piece, pull up slow until it comes out. Now the only thing holding it in is a clip at the bottom of that piece. It is hard to get but pull on it carefully and it will come. Now you have to remove the two screws from the switch to get rid of the plastic piece. Now look at the panel where you just took that piece off. There are two screws that need to be removed. The next thing is to remove the trim around the door handle, pry around it and it will pop out. That should be it, now you just have to lift the door up and out.
The fun part is putting the panel back on right, just take your time so you don't break any clips.
A
Aggie 08
30
Apr 18, 2006
  • Apr 18, 2006
Thanks for the info, I'm gonna start on it tommrow.
E
exindust
329
Moorpark, CA
Apr 18, 2006
  • Apr 18, 2006
This job sucks... i still need to pull mine back off and re align it...
both the driver and passenger are off and squeek every once in awhile.
AmBo
1,027
New Jersey
Apr 18, 2006
  • Apr 18, 2006
I was actually wondering this myself recently. My passenger door rattles a bit by the speaker. I punched it real good and I think my highly technical approach worked.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Z
91 LX 5.0 Hatchback door striker back plate fell.
  • Zeke1995
  • Jun 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Zeke1995
Z
