Doors
  • Thread starter Thread starter foxtrot152
  • Start date Start date Mar 6, 2016
F
foxtrot152
  • Mar 6, 2016
Hello all
I am in need of replacing the doors on my 1988 Foxbody Mustang. I have come across a 1979 Foxbody that has some really nice doors but need to know if they will fit on the 1988. I have searched the internet and cant seem to find any information on any changes that may have happened across the years to the doors.
Any help would be much appreciated.
Thanks in advance Todd
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 6, 2016
  • Mar 6, 2016
79-93 are the same size and frame- as long as you are replacing the same body style- coupe to coupe, convert to convert, T top to T top.
The inside door panels and locations of window and door switches are in different locations so you will need to swap them off your existing door., as well as the mirrors are different. 79-88 have the mirror located in the front corner of the window while the 89-93 have them mounted on the door.
F
foxtrot152
  • Mar 6, 2016
Thank you for the quick reply I will be able to swap the doors right over then because I have a 1988
Todd
90sickfox
Wasn't a pretty sight...and I've got big hands
Mar 2, 2015
6,953
5,831
213
Mar 6, 2016
  • Mar 6, 2016
The trim at the top of the door below the window on the outside is different but it will swap over with the round mounting brackets.( drill and rivet on new door ). The door handles are in different spots so all the linkage has to be swapped and the handle hole cut out. The inside handle mounting points will probably have to be modified (they are different). The mirrors are the same ( I believe ) from 79- 93. The only ones that change were convertibles. ( they moved to on the door )
F
foxtrot152
  • Mar 7, 2016
What if I am swapping the whole door out on the car Will it fit as it sits without any changes ?
Todd
Mustang5L5
Mod Dude
Feb 18, 2001
43,389
18,129
224
Massachusetts
Mar 7, 2016
  • Mar 7, 2016
What model 1988 do you have? Coupe? T-top? Convertible?
And what model are the 79 doors coming off? Does the '79 have power windows and locks?
F
foxtrot152
  • Mar 7, 2016
1988 hatchback gt is the car I need the doors to fit it is coming off of a 1979 Coup hatchback Gt
Todd
hsean
656
69
69
dearborn,michigan
Mar 7, 2016
  • Mar 7, 2016
they will fit but i would just find 87-93 gt doors a lot less hassle .that way you don't have to change moldings and window switch placement.
Mustang5L5
Mod Dude
Feb 18, 2001
43,389
18,129
224
Massachusetts
Mar 8, 2016
  • Mar 8, 2016
Todd
What roof on your GT? T=tops? Or sunroof/noroof?
Also, there wasn't a '79 Coupe hatchback GT. Is it a coupe? Or a hatchback? And more importantly, what roof is on the car. Sunroof, no roof, or T-tops.
Reason I ask is because the major difference is the shape of the glass and the upper door trim. T-top cars are unique and tend to require special doors. Also, the mirrors can be slightly different.
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Fox 5.0 Mustang Tech 42 minutes ago
Dakar09
D
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
