- Mar 4, 2004
- 259
- 0
- 16
explain powershifting please. this post should make me a senior member!!25thmustang said:Car in gear, clutch in, put into nuetral, clutch out. Clutch in, put into gear, clutch out...
Its a waste of time unless you are in a none synchronized tractor trailer...
Try powershifting for best results!
right on. as said, double clutching is for non synchro'd trannies (TT's, old british stuff [old cars period]).chrismillion said:explain powershifting please. this post should make me a senior member!!
Striped5.0 said:Poweshifting is when you dont let off the gas when you push in the clutch and shift. Its not a very smart thing to do w/ a T-5 Transmission but it will break it after time.
Black95GTS said:I will bow to your wisdom, Obi Wan, but what DO you call it when you shift without the clutch?
- Padowan Learner
