dr.side motor mount..how hard?
  • Thread starter Thread starter bensttype
  • Start date Start date Jan 1, 2005
bensttype
sd, ca
Jan 1, 2005
  • Jan 1, 2005
The 13/16ths nut on the driver's side mount keeps on spinnin' I can't get it to tighten so I need a new mount? How hard is it o replace w/ jackstands? Let me know.
thanks,
Ben
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 1, 2005
  • Jan 1, 2005
Always replace them in pairs - if one is shot, the other likely won't be far behind; if you only put one in, you'll simply accelerate the decline of the other. Ought to throw a tranny mount in while you're under there. Don't know how hard it is on yours; it's not too bad on mine. Just be careful under there.
79'293stang
505
11
29
Cedar Rapids, Iowa
Jan 1, 2005
  • Jan 1, 2005
its not to hard all u have to do is un bolt the mounts and jack the motor up
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jan 2, 2005
  • Jan 2, 2005
One more thing I would at least consider replacing is the bushings on the x-member. They're not hard to change -- especially if you're changing the tranny mount -- and it's about $10-$15 for poly ones that will help tighten things up.
HISSIN50
34
129
Jan 2, 2005
  • Jan 2, 2005
great advice from all. if you search posts by Jrichker, he has a little write up on the procedure with bolt sizes, etc.
parts store mounts are about 1/3 the price of poly (for 2 motor and one trans mount) - something to remember if budgeting. poly is real nice though.
also, if not using poly, i would use captured mounts from a 93 - verts had captured mounts before hardtops. by 93, ford was using the vert captured mount for all the stangs.
good luck.
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
M
Looking for a passenger side AC Compressor mount
  • mustangTodd
  • Feb 10, 2026
Classic Mustang Specific Tech Aug 22, 2026
s_mi11er
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
