drag guys; need input
  • Thread starter Thread starter NKau
  • Start date Start date Oct 30, 2007
NKau
1,346
Jefferson, WI
Oct 30, 2007
  • Oct 30, 2007
Alright, finally got my car to GLD after the new motor (mods in sig). Best time I ran was a 13.46 @ 103.53 with a 1.937 sixty foot. Figuring the car weighs roughly 3300 lbs. with me in it, that should equate to about 260 rwhp. I was hoping for a bit more, but my car is untuned, and I'm not exactly sure of what I have for a fuel pump. Anyone think some tuning will give me another couple mph? Kind of curious where I should go from here.
black87ttop
43
burlington,new jersey
Oct 30, 2007
  • Oct 30, 2007
a tune will def. help your car out, but your only about 5-6 tentsh off of what the car should be running. You should see high 12's. with that setup. and your 60's is killing your times as well. get that down a tenh or two and you will see some better numbers
1red95gt
31
Three Rivers, Mi
Oct 31, 2007
  • Oct 31, 2007
drag rads. and slicks go a long way
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Oct 31, 2007
  • Oct 31, 2007
Theres more in it with a tune... even on the 18s!
NKau
1,346
Jefferson, WI
Oct 31, 2007
  • Oct 31, 2007
Should have mentioned; I do have 16" ET streets for the track now. I got there late and without a pressure gauge, so I was making passes with 28 psi in the tires. It was only about 50 out and dark by the time I made my first pass, so I didn't expect much more for 60' times. Had the best results just slipping the clutch at 3500 rpm; anything more just spun, or wheelhopped.........which leads me to my next question......what do you guys typically run for pinion angle on your foxes? I'm on FMS c-springs all the way around, and have adjustable upper/lower control arms.
I really wanted to just get out and make a few passes to see where I was at in terms of power, and I see I have some work to do. I didn't think it would be too much to expect 107-108 mph trap speeds out of my combo with proper tuning...... Anyway, thanks for all your input guys.
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 31, 2007
  • Oct 31, 2007
The wheel hop issue sound like bad housing bushings, as far as tire pressure start at 20 psi and work down 2 psi till you get a slight spin as far as pinion angle i run -4 degrees to get it to hit the tires hard. you always have room for improvement with timing and fuel adjustments that sounds like a 12.8 car to me
NKau
1,346
Jefferson, WI
Oct 31, 2007
  • Oct 31, 2007
Never even looked at those when doing control arms; will check those out this winter.
I sure as heck hope so; I'm hoping better traps and 60' times once I get the engine/chassis tuning issues figured out it will happen.
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
K
Project Ideas (2006 S197)
  • Kitsune187
  • Apr 22, 2019
2005 - 2014 S-197 Mustang -General/Talk- Apr 22, 2019
Kitsune187
K
First Time Out With Drag Car...results Inside
  • Bullitt347
  • Sep 14, 2015
  • 2 3
7K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2015
mikestang63
Rotational Torque And Weight Transfer = Manual Transmission Shift Issues
  • Five.0GT
  • Sep 2, 2016
  • 2015 - 2023 (S550) Mustang -General/Talk
2K
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2016
84Ttop
Physics Or Dynamics Experts Only Please
  • FastDriver
  • Jul 5, 2015
  • Off-Topic Hangout
Off-Topic Hangout Jul 6, 2015
FastDriver
