Drag Springs???
do you want the car too sit low and look good or do you want it purely to hook? If you just want it too hook than I would just leave the stockers in there. They usually work better than aftermarket's. Otherwise Eibach makes a draglaunch kit but.... If you're getting pure dragsprings than check out the moroso TRICK drag springs
The Eibach drag springs combined with 90/10's helped my car go consistant 1.61 60fts
You'll be able to pull a wheel..lol
The weight transfer is night/day, I'm going to coilovers now.
Chris
Was he spraying outta the hole? The only bad thing about the S-Trim is that I have to launch all motor. I think with a hard launch on some kinda sticky tire 1.6's are doable even with almost all stock setup, but being on the verge of 1.5's consistantly is a big diff.
1.66 is movin...once I get a 2 step or something I should be able to get a load on the motor and launch with about 8psi :D
Chris
