  • SN95 4.6L Mustang Tech
Drain Plug
  • Thread starter Thread starter aggiemachfive
  • Start date Start date Jul 28, 2007
A
aggiemachfive
18
  • Jul 28, 2007
where's the drainplug on my transmission?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 28, 2007
  • Jul 28, 2007
automatic or manual? if its an automatic then it does not have one.
03gtdrkpny
79
IL
Jul 28, 2007
  • Jul 28, 2007
saw you other post, the auto has no plug, if you want to change your fluid/filter, you have to remove the pan. Save the gasket, it's probably good to go back on. if not get one from a stealership and get your filter from them as well. You'll need ~13 quarts of Mercron V.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 28, 2007
  • Jul 28, 2007
A. you wont need 13 qaurts if your simply taking off the pan, dropping the pan drained out for me probably barely 8 quarts. A lot of the fluid is in the TC which has it's own drain plug and up towards the output shaft which doesn't always wanna drain. The pan gasket is completely reusable.
B. don't put in Mercon V unless you've taken out all of you previous fluid, or if you were already running Mercon V.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 28, 2007
  • Jul 28, 2007
Ford recently back spec'd Mercon V to all applications except for those that specify type F, SP, or FNR5 fluid.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 28, 2007
  • Jul 28, 2007
yes, for good reason. I just dont promote mixing mineral fluid w/ synthetic ATF. If he's changing it all out at once, by all mean use MerconV
03gtdrkpny
79
IL
Jul 29, 2007
  • Jul 29, 2007
My drain pan is 10 quarts and it overflowed all over the garage floor. I didn't touch the tq and I put in almost 12 qts. your results may vary.
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
Block draining
  • JD1964
  • Mar 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 27, 2026
JD1964
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Help Identifying Engine Harness Plug
  • FoxbodyRob
  • Feb 7, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Feb 7, 2026
FoxbodyRob
