  • 1994 - 1995 Specific Tech
driveability issues?
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Dec 21, 2006
DDSTANG94
465
FRASER, MICHIGAN
Dec 21, 2006
  • Dec 21, 2006
In the future I will be putting AFR 165's heads, headers, and a performer intake manifold, I know the computers in 94 and 95 Gt's suck, so I plan to get a tune, but until I get the money for it I will have to drive my car without the tune. Should I expect drivability issues with these mods with no tune? Any knocking, surging or any of that *****. It a daily driver so I need it to run perfect. Also what should I set the fuel pressure and timing at. Thanks guys.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 22, 2006
  • Dec 22, 2006
Tons of posts have been done in these 94-95 forums about this very subject.
Some of them have been quite detailed
so
I'll hit just the basics for you in this reply
The pcm in our cars is quite different from the Fox pcm
and
in some areas of its programming, it has more potential
Most will tell you the cam is what gives the pcm fits.
While that can be true
its only part of the reason
you could suffer with drivability issues when you mod your Stang
Larger after market maf & inj's can really hose up your Stang as well
If you have issues with drivability ........
I'd not look at dizzy settings or fuel pressure
for your salvation from grief and frustration
With those mechanical methods, you just don't have a lot of options
When it comes to drivability issues ...........
a lot of it has to do with choice of combo parts
Where the problem lies is .........
If you pick parts to not freak the pcm .........
You leave power on the table
If you pick parts for max power production
You will definitely freak the pcm
Most of the time ... a tune is the solution for ..........
Maximum Power AND Maximum Drivability
Another frustrating thing about drivability issues
You can have two Stangs modded just about alike .........
Each one can act very differently when its all said and done
You most likely will have issues when you do the h/c/i mod thing
You may be able to find a bit of relief
with a higher idle in the range of 800 to 1000 rpm.
The tb air bleed screw can help produce a more stable idle as well
Invest some time and build your knowledge database
by reading past threads which contain excellent info
written by various members
Grady
Stanger007
2,015
Baton Rouge, LA
Dec 22, 2006
  • Dec 22, 2006
Find your tuner first... tell him your budget and what you want out of the car.
Definitely save the extra $500 or so the tune will cost ontop of your engine build costs and do it all at once. Nothing worse than having to daily drive a broked-up car - not to mention unsafe... why chance it.
Do it right the first time and don't worry about redoing it.
Wes
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
