Driveline vibration
  • Thread starter Thread starter 90LX5spd
  • Start date Start date Mar 19, 2006
9
90LX5spd
53
PA
Mar 19, 2006
  • Mar 19, 2006
My '90 LX 5 speed has developed a vibration in the driveline. One day it was fine, the next it started. The vibration gets worse with speed. It starts to become noticable at 25 and becomes progressively worse as speed increases. It does it in every gear, even if the transmission is pulled into neutral and the car left to coast. These things had me thinking wheel balance, EXCEPT the vibration goes away whenever the throttle is applied. A little throttle or alot, and no vibes. As soon as I back off the throttle, the vibes return. So it vibrates on decel, throttle off cruising and tranny-in-neutral coasting. Any ideas? The car has been driven easy (nothing over 3000 rpms and no overly hard driving) as the motor is still in the break-in period (under 300 miles). Thanks.
craigwhite89gt
181
Cecil County Maryland
Mar 19, 2006
  • Mar 19, 2006
1st thing i would do is check drive shaft bolts. Check engine/ tranny mounts also. make sure they havent wore out.
seijirou
2,417
DFW
Mar 19, 2006
  • Mar 19, 2006
Yeah what he said.
Look for play in the ujoints while you're under there, and take a peek at the ends of the driveshafts and see if you threw a weight. Throwing a weight will give you sudden vibration like a switch.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Mar 19, 2006
  • Mar 19, 2006
Do that, and if that is all good, check U-joints.
Worse case, the rear end could have a problem on setup, the coasting side of the gears not aligning correctly or a bad berring.
M
Mark89coupe
206
  • Mar 19, 2006
I used to get a serious vibration also. It was the tailshaft bushing in the tranny.
Not hijacking but-
I replaced the tranny and now I get a vibration at 80mph or better. Im guessing its the rear gears? Or possible the rear bearings? My rear tires are balanced.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Mar 19, 2006
  • Mar 19, 2006
well i had the same problem once and I swore it was the d/s i had everything ballanced and all. then i checked every ignition wire, and yup one was burnt out, i was having a miss that got worse with speed. so you might want to also check your cap and wires.
9
90LX5spd
53
PA
Mar 19, 2006
  • Mar 19, 2006
It was indeed the driveshaft bolts. At first glance they appeared flush with the flange but after putting wrench on them, I found 3 had just begun to loosen. Its funny you mention the ignition wire. My wife's Crown Vic Interceptor did the same thing and it was just a bad wire. Thanks.
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
