  • SN95 V6 Mustang Tech
Driver's Seat Interchange
  • Thread starter Thread starter pizon
  • Start date Start date Aug 20, 2008
pizon
14
Midwest
Aug 20, 2008
  • Aug 20, 2008
I have a 1997 V6 power driver's seat. I purchased a 2000 GT power driver's seat for a replacement. Issue: 1997 has a 2-wire power connector (1 black wire, 1 grayish w/stripe), 2000 has a 4-wire connector (2 black wires, 1 fatter than the other, and 2 green wires, 1 fatter than the other). Which wires from the 2000 do I use to connect to the 1997 and what is the setup, e.g. black to fatter green, etc.? Also, I read that the 2000 should have the seat belt buckle attached in order for the seat to receive power at all. Is this true, and if so, how can I get around that given the previously owner removed the buckle? Thanks!
pizon
14
Midwest
Aug 21, 2008
  • Aug 21, 2008
Seat working like a champ!
Mustang5L5
Mod Dude
Feb 18, 2001
43,264
17,952
224
Massachusetts
Aug 22, 2008
  • Aug 22, 2008
Was gonna answer but looks like you figured it out on your own.
You only bought a drivers seat though? No pass seat?
P
paulfromnj
nj
Oct 16, 2008
  • Oct 16, 2008
same problem need help
hey whats up . how did u fix ur problem . i have 95 .and i got a 2001 seat mustang . ttheone has 4 wire . and car has two . please help me how to resolve it . and the sitbelt too .thanks .john
pizon
14
Midwest
Oct 20, 2008
  • Oct 20, 2008
I cut off the 2 wire plug connector from the original seat and spliced it into where the 4 wire conector was in the new seat as follows: On the 4 wire plug there were 2 green wires, 1 black and 1 striped wire. I twisted the 2 green together and the other remaining 2 together - I now had 2 wires. I then attached the 2 green wires to the 1 colored wire from the 2 plug connector and the other 2 to the black wire from the 2 plug connector. Worked perfectly, the lumbar even works! Remember to remove the fuse under the hood first ---learned that the hard way!
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
9
Plug identification
  • 92Car
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
