Drivers side alternator
Whos done trhe conversion to drivers side alternator and which method did you use?
Breezy Auto kit
Moroso Kit
Crown Vic?
Other?
Lets see some pics before I spend $139 on the breezy kit
Heard on hardcore 5.0 that most moroso kits,along with March had a lot of adjusting to be done due to the spacers length being off.Their site is linking to **** again.
a really cheap alternative is to cut up you factory bracket and leave it on the passenger side. I'm only running a belt around the alt and the crank. i use an adjustment rod between the alt and a stud on the water pump that gives enough tension on the belt to run the water pump
