  • SN95 4.6L Mustang Tech
drivers side plugs solid black.. passanger perfect! Ideas?
  • Thread starter Thread starter forum155pl
  • Start date Start date Apr 11, 2007
forum155pl
520
the 509
Apr 11, 2007
  • Apr 11, 2007
Just as the title says.. all 4 of my drivers side plugs are all black.. they look like carbon build up not oil... the passanger plugs are all perfect looking.. they are motorcraft plugs that i put in about 4 months ago..
all were gapped at .40 (i have the PI swap)
any ideas? i'm thinking o2 sensor but i didnt want to go off and buy one till i talked to you guys..
thanks..
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 11, 2007
  • Apr 11, 2007
most likely cause of one bank running rich is a bad 02 sensor, but I would also check your injector pulse for both banks and see if one is much longer than the other.
A exhaust leak can also cause this...
forum155pl
520
the 509
Apr 12, 2007
  • Apr 12, 2007
how do i check the pulse?
i put on longtubes when i did those plugs and the ones i took out were exactly the same, i thought it was an exhaust leak then, but now i know there isnt any leaks..
Superhereaux
chicks make me feel inadequate
538
South Texas
Apr 12, 2007
  • Apr 12, 2007
not too familiar with pre-99 4.6's but aren't there 2 coil packs, 1 for each bank?
might be something to look into maybe
CobraRed_96_GT
1,421
UCSD/La Jolla
Apr 12, 2007
  • Apr 12, 2007
yeah, there is two coil packs, but 2 plug wires from each coil pack track to the other side's spark plugs. If one pack when out you'd have 1,3,5,6 go out or somthing
forum155pl
520
the 509
Apr 13, 2007
  • Apr 13, 2007
ive changed the packs to f150 packs.. new wires, and new plugs.. and i still got it.. it bucked like crazy on my way home from work just now.. i'm just going to replace the 2 front o2's they are the stockers anyways...
Superhereaux
538
South Texas
Apr 13, 2007
  • Apr 13, 2007
cool, i learned something today
well that eliminates spark, guess fuel trim it is. if the o2's are stock (10yrs old) then yeah might want to try that
no check engine light? exhaust tick in the morning?
forum155pl
520
the 509
Apr 13, 2007
  • Apr 13, 2007
no lights or codes.. i have a tick all the time.. but its not an exhaust tick.. i have no idea on what that is..
Mike97gt
it doe snot
10,633
Apr 13, 2007
  • Apr 13, 2007
So it' misfiring too? BTW checking the injector pulse width requires a scan tool that is live data capable
Are you burning any oil? any coolant? it's possible that a bad head gasket can cause low compression on that bank, cause the fouled plugs and misfires too.
Another thing to look at is a possible cam timing issue on that bank.. Check the cam sprocket on the bank with the black plugs, we have seen some sprockets crack causing cam timing issues on one bank.
forum155pl
520
the 509
Apr 14, 2007
#10
  • Apr 14, 2007
  • #10
i'll check into that cam timing... i have a leaky timing cover gasket anyways... a buddy of mine has a MAC scantool, i'll get him to scan it for me... thanks guys!
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
