drivers side plugs solid black.. passanger perfect! Ideas?
forum155pl
520
the 509
Just as the title says.. all 4 of my drivers side plugs are all black.. they look like carbon build up not oil... the passanger plugs are all perfect looking.. they are motorcraft plugs that i put in about 4 months ago..
all were gapped at .40 (i have the PI swap)
any ideas? i'm thinking o2 sensor but i didnt want to go off and buy one till i talked to you guys..
thanks..
ive changed the packs to f150 packs.. new wires, and new plugs.. and i still got it.. it bucked like crazy on my way home from work just now.. i'm just going to replace the 2 front o2's they are the stockers anyways...
yeah, there is two coil packs, but 2 plug wires from each coil pack track to the other side's spark plugs. If one pack when out you'd have 1,3,5,6 go out or somthing
cool, i learned something today:nice:
well that eliminates spark, guess fuel trim it is. if the o2's are stock (10yrs old) then yeah might want to try that
no check engine light? exhaust tick in the morning?
So it' misfiring too? BTW checking the injector pulse width requires a scan tool that is live data capable
Are you burning any oil? any coolant? it's possible that a bad head gasket can cause low compression on that bank, cause the fouled plugs and misfires too.
Another thing to look at is a possible cam timing issue on that bank.. Check the cam sprocket on the bank with the black plugs, we have seen some sprockets crack causing cam timing issues on one bank.
