  • 1994 - 1995 Specific Tech
Drivers Window Will Not Work
  • Thread starter Thread starter fawcett
  • Start date Start date Apr 25, 2010
fawcett
380
Cohasset, Ma
Apr 25, 2010
  • Apr 25, 2010
About 3 years ago my passanger window stopped working, so I replaced the motor and it solved the problem. Now my drivers window wont work.
I have the door apart, I removed and replaced the motor but when I go to click the button I get nothing.
I've swapped the passanger side window switch to the driverside location and get nothing.
I've put the drivers side switch on the passanger side location and got nothing.
(I think its safe to assume that my drivers side switch is bad.)
I've looked at the fuses both under the hood and under the drivers left leg and everything checked out fine.
I don't know where else to check, I feel as if the box where the wires meet the switches may be the problem but thats just a guess.
I should note that when performing the tasks above, I did not have my power window mirrors hooked up, nor did I have the "alarm system?" plugged in. (I am referring to the black box located in the corner of the door closest to the drivers side rear wheel.)
What am I missing?
ProKiller
3,064
15
78
PA
Apr 25, 2010
  • Apr 25, 2010
did you check the bushing? they commonly break. do a search for it. there are a couple write ups for replacing them.
HISSIN50
34
129
Apr 26, 2010
  • Apr 26, 2010
Did you ever simply connect fused battery power to the motor to see if it would energize? A bench test like this is quick (it can be done in-car).
fawcett
380
Cohasset, Ma
Apr 26, 2010
  • Apr 26, 2010
ProKiller- those bushings you are referring to are located inside the window motor right? I only ask because I replaced the motor. I could be way off though and if I am where do I look for them?
Hissin- I hate to say this but I don't know anything about how electricity works-how would I do this?
I know I should have a volt meter for this and I don't. Maybe I can borrow one from a friend to confirm that the location which the drivers side window switch plugs into is not getting power.
ProKiller
3,064
15
78
PA
Apr 26, 2010
  • Apr 26, 2010
yeah they are part of the motor i thought.
Here's one of the better how-tos I've come across.
How to repair window motor bushing - 94/95 cars only
HISSIN50
34
129
Apr 26, 2010
  • Apr 26, 2010
There's only a power and ground wire to each motor. The polarity varies depending upon which direction you're going. You could use a test light (or make one).
When the bushings go, generally the motor still makes noise (but it's just spinning the output shaft).
For bench testing, something along the lines of some spare 12 gauge wire with a 10 amp fuse would be fine for the test.
E
eatsricejcd
76
  • Apr 26, 2010
most likely your bushings mine were completely gone. really easy to check to see if they're gone. I dont know crap about cars and I could do this. just read the tutorial above
I
Itkix
116
  • Apr 26, 2010
Make sure youve plugged that relay in the one you have to unplug to take door panel off, when I first got my car driver window wouldnt work and someone had unplugged that relay for some reason. I think if you have door panel off relay isnt plugged in. Just a thought.
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
Rear window failure
  • Moondog2178
  • Jul 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2025
Moondog2178
Paint and Body Window bushing
  • JD1964
  • Aug 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 19, 2025
General karthief
