  • SN95 4.6L Mustang Tech
Driveshaft?
  • Thread starter Thread starter scupking
  • Start date Start date Feb 9, 2008
scupking
1,186
Enfield, CT
Feb 9, 2008
  • Feb 9, 2008
I'm going to be putting on an FRPP aluminum drive shaft in a few days. I have an automatic, now if I remember correctly I need to use my yoke from my current D/S right?
N
Nightstick
68
  • Feb 9, 2008
Yep. Was gonna do that myself but decided on one of these instead:
http://www.need-4-speed.com/pst.htm
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Feb 9, 2008
  • Feb 9, 2008
Correct. Car should feel smoother after the install. Mine seemed to rev a little smoother and faster with the new DS.
scupking
1,186
Enfield, CT
Feb 10, 2008
  • Feb 10, 2008
Yeah I'm looking forward to that. After the gear change I noticed some vibrations.
scupking
1,186
Enfield, CT
Feb 10, 2008
  • Feb 10, 2008
I paid just over $200 for the aluminum. I did look at the ones your talking about but they are so expensive.
CobraRed_96_GT
1,421
UCSD/La Jolla
Feb 10, 2008
  • Feb 10, 2008
hmmm cams with valve springs or a new driveshaft.................
fobra559
Nov 1, 2007
721
Lindsay, CA
Feb 10, 2008
  • Feb 10, 2008
Good Point.
Notchbck93
422
IL
Feb 11, 2008
  • Feb 11, 2008
Between the yolk on your rear pinion and the yoke on the back of the tranny you should have a 1 degree difference. If not, shim the back of the tranny and your vibration should be gone.
http://www.drivetrain.com/driveline_angle_problem.html
You've increased the speed of your driveshaft by changing the rear gear ratio; adjust accordingly.
joshheat25
871
Delaware
Feb 12, 2008
  • Feb 12, 2008
Yea my car was alot smoother with the new driveshaft and new rear tranny mount, seal, bearings. huge difference. Going 70-80 on the hwy it's so much smoother!
geoffsgt
176
Baton Rouge, LA
Feb 12, 2008
#10
  • Feb 12, 2008
  • #10
Eh? D/S still moves at the same speed... engine speed modified by whatever gear you happen to be in.
CobraRed_96_GT
1,421
UCSD/La Jolla
Feb 12, 2008
#11
  • Feb 12, 2008
  • #11
shhhh, logic isn't welcome here
Flghtmstr1
572
Springfield, PA
Feb 13, 2008
#12
  • Feb 13, 2008
  • #12
I'm not so sure that's the best way to look at it. For the same vehicle speed, the driveshaft will be spinning faster in a car with a higher (numerical) rear gear ratio. So, on average, your driveshaft will be turning faster after a gear install (unless your driving slows down to compensate)
CobraRed_96_GT
1,421
UCSD/La Jolla
Feb 13, 2008
#13
  • Feb 13, 2008
  • #13
edit: i had it backwards. going 60mph with 3.27's the wheel is spinning at 60 mph and engine may be at X rpms. 60mph w/ 4.10's means wheel is still spinning at 60mph but the engine is at 1.2X rpms therefore the driveshaft is having to spin faster to go the same speed
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Hi from Western Washington
  • Bannister
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 31, 2026
keel
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
