  • SN95 4.6L Mustang Tech
Driving problem
  • Thread starter Thread starter jimmy01cobra
  • Start date Start date Dec 27, 2011
J
jimmy01cobra
20
Hawaii
Dec 27, 2011
  • Dec 27, 2011
When I am driving at any point of pressing the gas, my car starts to jerk. This happens through all gears and is highly noticeable when gas is pressed all the way. Couple days ago I decided to wash my engine to see how easy/ clean it would get. Didnt see any problems until today when I went for a cruise. Could this be cause there is moisture in the vacuum lines, throw out bearing, clutch slipping. Also, I can hear a pop coming from the exhaust when at idle. Ill post a video tomorrow for more clarification!
2001 Mustang Cobra 120k
Three50won
1,135
64
69
Dec 27, 2011
  • Dec 27, 2011
It sounds like it might be spark related. Are you due for a tune up? Check those wires and the plugs...
Reactions: jimmy01cobra
trinity_gt
3,125
81
99
Canada
Dec 27, 2011
  • Dec 27, 2011
You've gotten water inside the spark plug wells. Pull the plug covers and the coils off each plug. Use compressed air to blow out any water in and to dry the wells. Use same compressed air to blow out the boot end of each coil. Place a daub of dielectric grease inside the boot and re-install.
Don't wash your engine with running or pressurized water again. There are too many sensitive electronics whose connectors are water resistant versus water proof and too many ways for liquid water to get where it shouldn't.
J
jimmy01cobra
20
Hawaii
Dec 27, 2011
  • Dec 27, 2011
Ok ill give this a try when I have time today, Thank you for the quick responses!
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Dec 27, 2011
  • Dec 27, 2011
... check for moisture under the Cap too.
J
jimmy01cobra
20
Hawaii
Dec 27, 2011
  • Dec 27, 2011
checked them and found out that some water did get into the rear passenger side, number 7 I think. All is better now. I hope it doesn't cause anything to rust/corrode. Going to put some anti seize when the engine cools down.
trinity_gt
3,125
81
99
Canada
Dec 27, 2011
  • Dec 27, 2011
Don't worry about corrosion. The engine heat will evaporate any remaining water. The liquid present was shorting spark energy on that cylinder causing a misfire. Now that you've dried out the worst of it any remaining will dissipate on its own.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
