6five_stang,
I just did this same thing with my '65 289, c4. I don't know where you're getting the kit but you can get it from discbrakeswap.com. He's also on ebay. I don't remember exactly but the whole kit was like $550 give or take a few. New mc, spindles, calipers, pads, prop. valve, instruction cd,...everything you need. The guy is awesome for answering questions and helping you out. Highly recommend. Now to your question. Yes. I stayed manual due to the fact I wanted to keep the manual feel for the car and a new booster is around $250 You will also need to run a vacuum to the intake for the power booster. You may encounter problems pulling enough vacuum at idle depending on the cam which you will need to buy a canister from what I have read. Search the internet for this. (Booster can be added later if you want) Also, manual brakes stop the same whether the car is running or not...nice if you've ever had one stall. You'll have to re-route some brake lines, no big deal just don't kink 'em. You'll need adapters to get the brake lines into the granada mc. Email me and I'll tell you where and part numbers to avoid a lot of time searching. It's pretty simple and straight forward. Again, Dennis at discbrakeswap.com is awesome. Check your ball joints and tie rod ends. If they are worn out now is the best time to replace 'em. Let me know if I can help in any way. I just finished this with a lot of other stuff and have turned a lot of wrenches in the past three months and can hopefully save you some time. One more thing, is your car original I6 or 289?
Duane
