Dumped Codes - Code 33
  • Thread starter Thread starter srothfuss
  • Start date Start date May 21, 2005
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
May 21, 2005
  • May 21, 2005
I had my dad pull the codes in my car this morning (I am on assingment for work right now so I couldn't). Anyway Code 33 showed up in the stored memory for KOEO and also during KOER. This is the only code that showed up. I know that this is "insuficient EGR flow" but I need to know what to clean / replace since I don't really know about the EGR system yet.
Any help is greatly appreciated!
Thanks,
-Steve
stang22
1,318
Washington, D.C.
May 21, 2005
  • May 21, 2005
The EGR valve sounds like it is stuck in the closed position. I am not sure if you clean it and make any difference, but it is worth a shot. If it is bad, it will need to be replaced.
33 ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently -
You can also reset the computer and see if the code comes back. To reset the computer, disconnect the battery for about 10-15 minutes.
Tim
Black1987Stang
1,422
Jersey Shore
May 21, 2005
  • May 21, 2005
I got the same code too but i found out i didnt have one of the vacuum lines conected to one of the diverter valves connected to the smog pump. i hooked vacuum to it and im still getting the code, I no im getting vacuum but it must be stuck cuz, the code keeps coming back. Double check ur vacuum lines going to the diverter valves.
HISSIN50
34
129
May 21, 2005
  • May 21, 2005
JRichker has a very nice write up about checking out the EGR (he has several actually, but one is for just code 33). if you are in EGR conditions, do you get vac to the valve itself? if EVR is supplied with constant vac and regulates the air to the EGR valve itself.
good luck.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
May 21, 2005
  • May 21, 2005
I am getting vacumm to the valve. I think that it's just dirty. When I get back from Mexico, I will take it apart and clean it out.
In the mean time, I will look up the write up on code 33.
Thanks guys!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 21, 2005
  • May 21, 2005
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal flickers. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1 ohm.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
HISSIN50
34
129
May 21, 2005
  • May 21, 2005
the man has come through!
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Ran my code reader and
  • Mindseye007
  • Aug 10, 2024
Fox 5.0 Mustang Tech Aug 19, 2024
Mindseye007
