During Nitrous pass, coolant overflow OVERFLOWS????
  • Thread starter Thread starter Stang8URMPRT
  • Start date Start date May 23, 2004
Stang8URMPRT
1,100
Daytona Beach, FL
May 23, 2004
  • May 23, 2004
Like I said... When I make a nitrous pass, coolant rushes into the overflow and out. Do I just need a new, higher pressure cap? I know the head gaskets are fine and no smoke out the car. Whatcha think?
Nick
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
May 23, 2004
  • May 23, 2004
How do you know the head gaskets are fine? That would be my number 1 answer.
IndyBlk5.0
1,122
New Whiteland, IN
May 23, 2004
  • May 23, 2004
me says headgaskets.
Stang8URMPRT
1,100
Daytona Beach, FL
May 23, 2004
  • May 23, 2004
Because this happened the same way with the last motor. After I melted a piston, I pulled the motor and the head gasket was FINE. Like fuggin' new. But it melted a piston. So I say it's not a head gasket because I know from experiance. I've been told by some others that this builds head very fast and causes a high pressure in the cooling system which opens the cap up and lets it all flow to the overflow.
Nick
SLiM JiM 156
1,024
Rohnert Park, CA
May 24, 2004
  • May 24, 2004
how old is the radiator cap, the only thing other than a head gasket that i can think of is when you spray, the coolant gets so hot it pops the cap spring and blows steam in and makes it overflow..
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
May 24, 2004
  • May 24, 2004
It's because under the extra stress of the nitrous you are lifting the heads and pushing combustion gasses into the coolant system. Same as a blower car with too much boost and too much timing. Been down this road many times. Back the timing off on your next run and see if it goes away.
Jamie
F
forrealb50
163
VA
May 24, 2004
  • May 24, 2004
My stang is doing the same thing. I don't think it's a headgasket problem rather a head bolt problem. I sent you a pm...
Stang8URMPRT
1,100
Daytona Beach, FL
May 24, 2004
  • May 24, 2004
Jamie
You're the man. I'll try that. I enrich with 114 octane, so I didn't think detonation was a problem. i can't hear detonation. But I have heard of the combustion pressure lifting the heads.
Nick
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
May 24, 2004
  • May 24, 2004
Check see if lower hose is colapsing during the run, if there is no coil in the lower hose it could be collapsing causing a pressure spike.
dastang2
2,020
tx
May 24, 2004
#10
  • May 24, 2004
  • #10
lol, how would he see the hose while going 100mph. just messing with ya, how old are the head bolts, how much psi is the radiator cap and squeeze the bottom hose to feel for a coil spring.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
May 24, 2004
#11
  • May 24, 2004
  • #11
Dow...ok you got me on the checking the hose during the run, but seriously you should always look at every posibility and if the hose does collapse the pressure has to go somewhere.
Stang8URMPRT
1,100
Daytona Beach, FL
May 24, 2004
#12
  • May 24, 2004
  • #12
You guys are being very helpful and I thank you. That's why I come on here and give all the advice I can give. Because you get it in return. . As far as the lower hose having a coil in it, it doesn't... The head bolts are ARP and about a year and a half old. The radiator cap is 13 psi I believe. Maybe I should get a 16 psi cap and a coiled lower hose.
Nick
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
