Dynamat
  • Thread starter Thread starter maximos
  • Start date Start date May 28, 2008
maximos
188
Columbus, OH
May 28, 2008
  • May 28, 2008
Is Dynamat meant to take the place of the foam insulation that is attached to the door panels?
Thanks in advance.
95WhiteVenom
624
Alabama
May 28, 2008
  • May 28, 2008
It can be used that way. Dynomat's main purposed was to stop your car from rattling apart when having large stereo systems in the car, as well as deadening the sound of racecars as well. This material will greately reduce the exterior noise of a cars interior therefor providing you with a quieter ride.
95BlueStallion
My assy trans to myself
5,126
3,091
214
Cedar Rapids, Iowa
May 28, 2008
  • May 28, 2008
However, it tends to be heavy, so loading your car down with it will add a good amount of weight. Most people dont care, but Im a poor boy trying to make my car faster any free way possible!
maximos
188
Columbus, OH
May 28, 2008
  • May 28, 2008
I was given a Dynamat door kit, I went to install it and I ended up postponing the project since I wasn't sure if the foam needed to remain where it's at...Does it provide any type of support for the interior panel at all? My audio system isn't anything fancy, but the doors sure do rattle a lot when I get the music going.
95WhiteVenom
624
Alabama
May 28, 2008
  • May 28, 2008
That will help with ya noises.
T
turbogt
723
Montana
May 28, 2008
  • May 28, 2008
no, it is meant to dampen vibrations, not absorb sound...
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
May 28, 2008
  • May 28, 2008
Dynamat will NOT replace the foam in the door panel. While the foam does help with sound insulation, I found it also helps heel the panel from flexing too much. If you remove the foam, you'll likely get a creaky panel whenever you put your arm on it.
You can cut off the plastic sheet glued onto the door - that's there for sound insulation only.
I personally recommend Cascade Audio for sound insulation - it's thinner, molds to the shape of the door better, and dampens the sound better. Though it is more expensive.
Pokageek
2,767
MA, USA
May 28, 2008
  • May 28, 2008
I once had a small car. It had no insulation in the door panels and sounded like tin when shutting the door. I attached dynomat to the inside of the metal door and shut like one them marcedees every since! Yes it works! I like it.
R
reldapimp
94
  • May 28, 2008
yeah dynamat works really good. but this is better
http://www.secondskinaudio.com/
Door wiring, Unknown plug
  • TripleYellow
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
gkomo
G
Mass Backed Carpet over OEM Underlayment
  • GotMojo
  • Jun 3, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 3, 2025
horse sence
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
J
67 mustang interior courtesy light wiring
  • JCuster
  • Jun 9, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GypsyR
G
T
1979 Inner Door beltline/dew wipe replacement part
  • toasterboy1
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2025
MinervaHBanta
M
