DYNO question.
  • Thread starter Thread starter dwpred50
  • Start date Start date Aug 8, 2004
D
dwpred50
41
  • Aug 8, 2004
Hi,
I was just wondering when your car is on the dyno what exactly are you spose to do? What gears you go through and and how you go about going through them?Any help would be great.
dwp
blown1989saleen
1,397
oxford,pa
Aug 8, 2004
  • Aug 8, 2004
its basically just like your driving, start out in first to get the rollers moving, go into second and letting the clutch out smoothly, go into third doing the same, then go into fourth and go up to 3000 and then go to WOT till you get to the RPM you want to pull to. DO NOT touch the brakes the dyno operator will control the brakes on the dyno roller. most places dont let you do your own dynoing but the dyno i go to(xotic motorsports, cochranville, PA) lets you
Scott
Scott
04sleeper
2,674
14
89
Dallas, TX
Aug 8, 2004
  • Aug 8, 2004
When your car is strapped to the dyno you will just run it easily through the gears until you get to 4th. Then when you are ready to kick it down you start the switch to start the run. You kick it down and bring it up to the desired max RPM. When you let off you let off the switch. This will graph your run.
BTW, Sweet looking car!
D
dwpred50
41
  • Aug 8, 2004
Ok thanks, I was just making sure we did it right at the dyno the other day because in 4th gear we were moving up to 6 grand @ 175 mph and the head gasket blew.
dwp
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
