E-cam
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Jan 20, 2006
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Jan 20, 2006
  • Jan 20, 2006
I got an awesome deal on an e-303 cam so i am purchasing it and i am gonna put that in along with a set of GT40p heads 1:6 roller rockers, exploder intake, mass air conversion, and 65mm TB. Will this combo be more noticeable then stock? How many of you run this type of combo and what are your times with it?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 20, 2006
  • Jan 20, 2006
anything will be better then stock.
86mustang5.oh
125
battle creek mi.
Jan 20, 2006
  • Jan 20, 2006
i was thinkin of the same combo but a better cam and a blower...........
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 21, 2006
  • Jan 21, 2006
i dont have the combo but i am sure it would run great. The e cam isnt too wild, will definatly use those heads, but wont rob you totally of your low end.
White89GTstang
32
Fresno, CA
Jan 21, 2006
  • Jan 21, 2006
Awesome cam, great sound, the lope with turn some heads. Can be a "woman" when its cold.
SamSnyder
196
  • Jan 21, 2006
Left my GT40 iron head, E303, Mac shorty, BBK 2.5" cat h-pipe, 2 chamber Flowmaster '90 LX idling at the ATM machine while I made my withdrawal, and the guy next to me looked at it and said: "That's the way they should sound, it's cool." And it was.
legalize420
1,541
South Florida
Jan 21, 2006
  • Jan 21, 2006
big difference over stock. time in my sig. that was with stock gears and only my third time ever going to the track. car can go 12's when i get some more track experience and some traction. with that 2.4 60' i was spinng through first. i get so many complements for the way my car sounds.
RsStanG1987
569
9
79
Dupont PA
Jan 21, 2006
  • Jan 21, 2006
Sweet im hoping with this combo to get low 13's when i learn to launch better. Im basicly buying this stuff and letting it sit before i install. Im planning on installing it over the summer while im on vacation at my fathers.
RYC CUKR
1,437
Orlando
Jan 21, 2006
  • Jan 21, 2006
You'll be running pretty much the same combo that I used to have minus the 3 cam as I was still running a stock cam. It was good for 14.18 @ 98mph in an AOD vert with 4.10s.
One thing to definetely do is change out the springs on those p heads so that they match the lift of the e cam. I do not believe that the stock explorer springs will work. I just got that trickflow spring upgrade kit for gt40 iron heads and put them on. Also I don't think that your stock exhaust manifolds will work with the p heads due to the spark plug relocation. I would hunt ebay for a nice set of ceramic coated p specific headers. It took a little while but I got a brand new set of FRPP ceramics for $150 shipped
My old combo was 70mm tb, 1.6 rr, GT40P heads, full exhaust, GT40 intake ( explorer lower, tubular upper, stock cam, 4.10s and smog and EGR delete. Went 14.18 @ 97.98. New combo is 70mm tb, 1.6rr, GT40P heads, fulle exhaust, Trickflow Trackheat, TFS stage 1 cam, 4.10s and smog delete. Last time I was at OSW I went 14.24 @ 100.03. So I am making more power but having a harder time getting it on the pavement. Hopefully my new DRs will help solve that problem.
Let me know if you need a hand. Should take about a day to intall heads, cam and intake. Not sure about mass air conversion.
It will be a lot of fun.
QDRHRSE
1,590
Palmdale, CA
Jan 21, 2006
#10
  • Jan 21, 2006
  • #10
If you have enough gear in the car and some tire I don't see why you couldn't crack the 12's. Mid to high 13's on radials if the car runs good.
1mild88lx
49
Northern California
Jan 21, 2006
#11
  • Jan 21, 2006
  • #11
My combo is somewhat close to yours, it feels alot stronger than before. I installed my H/C/RR 3 weeks ago. Im going to the Track when I get some Drag Radials in March. Good luck and post your E.T. :SNSign: .
RsStanG1987
569
9
79
Dupont PA
Jan 21, 2006
#12
  • Jan 21, 2006
  • #12
Well right now i have full exausht and the headers are bbk and will work with gt40p's Im doing the swap in PA because he has a garage. If anyone down here would let me use theirs i would do it there but until then i play the waiting game..
88stangmang
#13
  • Jan 21, 2006
  • #13
Thats close to my set-up. Except I have stock heads. Runs high 13.20's to low 13.30's on slicks.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 21, 2006
#14
  • Jan 21, 2006
  • #14
Sounds like a good combo.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 21, 2006
#15
  • Jan 21, 2006
  • #15
Oh and use stiffer springs. Some of the worst disasters imaginable are caused by loss of valve control.The idea that stiffer springs eat up hp is a myth. Think about it, there are always the same amount of valves being open and closed at the same time, stiffer springs aren't going to ad that much more resistance. I'd rather have stiffer springs than floating valves. Cause the first time you take it through the gears and you float the valves your going to be pissed...ill tell you that from experience.
1990LXDropTop
430
Western Massachusetts
Jan 21, 2006
#16
  • Jan 21, 2006
  • #16
I have edelbrock heads/intake, and a crane 2040 came (same as e-cam). I LOVE it as my spring/summer daily driver. The cam has great street manners while still yielding good power and it passes the sniffer with flying colors in most cases.
MadDAWG_zr2
64
#17
  • Jan 21, 2006
  • #17
I have ported e7's, e303 with 1.7s and explorer intake in a 90 gt with a 5spd and 3.73 gears. It ran 13.25 on good tires. I'd like to swap the shorties for long tubes. That and some tuning should net a 12 second slip.
It did loose a little low end over stock, but picked up plenty up top.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
