  • SN95 V6 Mustang Tech
Eaton M90 SC
  • Thread starter Thread starter xstangx
  • Start date Start date Jun 18, 2004
xstangx
22
  • Jun 18, 2004
I just wanted somebody to point me in the right direction real quick. Does anybody know where to get a kit for the eaton sc out of the supercharged thunderbirds. I can get the whole setup out of one from the shop i work at. But i wanted to know something first, like does anything fit together? Mostly if there is a kit for installing one, that would be the best. Thanks guys, and gals.
98CobraClone
592
Ripley, Ohio
Jun 18, 2004
  • Jun 18, 2004
Too many modifications needed to make it fit on a split port engine like what you have. You've have to change your heads and several other things. You're better off to get a manufactured kit (vortech, procharger, etc.) that way you know everything will work just fine with no modifications/fabrication
T
Thordic
41
Cedar Grove, NJ
Jun 18, 2004
  • Jun 18, 2004
I actually looked at this a while ago because I could have gotten an Eaton cheap.
Basically, the "easiest" way to do it involves changing your engine back to a single-port, but this causes you to lose the 40ish HP gain the 99+'s had over the pre-99 models.
So you are giving up 40 HP right off the bat, before you get the SC installed.
I doubt the power gain would be worth it.
super6
philly area
Jun 20, 2004
  • Jun 20, 2004
http://www.3.8mustang.com/forum/showthread.php?t=79867
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
2K
Fox 5.0 Mustang Tech May 6, 2026
AeroCoupe
Eaton TVS style supercharger for small block Ford
  • nicholase
  • Jan 2, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2025
H
Transmission Help
  • Harman78
  • Feb 20, 2025
SN95 V6 Mustang Tech Feb 21, 2025
Harman78
H
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Jun 28, 2026
joeybuddy96
J
