19mustang65 said:
does a high rise make a big enough diff to go out and buy one when i already have a rpm? what does a high rise actually do? also, i hear things about carb spacers? if i was to get one what brand model ect?
The RPM is considered a "high rise" intake.
That is not a very technical term though.
The more correct terms would be single plane, dual plane, tunnel ram, 180 degree, etc...
You can have a low or high rise anything and it doesn't make nearly the difference as the other terms.
To the question of which is best for you, that all depends on your combo and what you primarily do with your car.
For all around street manners and rv cam, the RPM is a good intake. In your shoes, I would have to be really unhappy to go and remove that intake and start experimenting with new ones.
Dave
Edit: The carb spacers are generally a 'band-aid' for an intake that lacks performance in a desired rpm range.
A four hole spacer adds torque and throttle response by giving the carb a stronger vacuum signal at the throttle blades. The open spacer does nothing for vacuum signal to the carb, but adds plenum area for higher rpm operation. This can make the low rpm response a little softer and may require a larger accellerator pump in some cases.
The taller the spacer, the more magnified these qualities become.
My experience with the RPM was that it was a very mild intake and lacked top end, so I ran mine with a 2" open spacer. It added a few usable rpm up top, but not much.
