EEC-IV BBF?
  • Thread starter Thread starter Hickfied
  • Start date Start date Sep 14, 2007
Hickfied
413
Morganton, NC
Sep 14, 2007
  • Sep 14, 2007
Has anyone seen one? I have been building a 460CI SBF (waiting on heads & shortblock), but the only reason I was staying SB was because of the FI.
I have been thinking, and I can use a carb intake w/ injector bungs, and a elobow for my TB. I think the only thing that would hold me up would be the distributor? Is there one in the aftermarket with a TFI setup that I would need for the 87-93 fox? Or even OEM?
Does anyone see other limiting factors on a "drop in" FI BBF?
RYC CUKR
1,437
Orlando
Sep 15, 2007
  • Sep 15, 2007
I was looking around the engine management section over on corral and there were some posts from guys running EEC-IV on their big blocks. Might want to check them out or check out ford460.com
57fairlane
560
Oakwood, GA
Sep 18, 2007
  • Sep 18, 2007
The mid 90s F250s had EFI 460s.
Can't remember if its TFI or not . . .
Hickfied
413
Morganton, NC
Sep 18, 2007
  • Sep 18, 2007
They did had a TFI module, but it was a remote setup, such as the SN95 5.0's.
I found this link on how to retrofit a tfi module onto the dizzy:
http://www.detomaso.nu/~thomast/efi/
rj95svt
422
Hayden, AL
Sep 18, 2007
  • Sep 18, 2007
I have seen pictures of a fuel injected 460BB in a lx.
I believe the 460 uses the same distributor as the 351w's don't they? If so it wouldn't be hard at all to do a fuelie 460! The hardest part then would be finding a hood that will clear a setup like this with a intake elbow and throttle body.
M
macx
228
SE Missouri near Cape Girardeau
Jan 17, 2008
  • Jan 17, 2008
That remote mount setup is actually better at least from the standpoint
of the tfi module not failing due to all the heat from the engine and radiator.
Would be far best to get the distributor, short wiring harness, and the
tfi module receptacle all together than to try to modify any existing distrib.
If you get one off a 460 you're all set.
Then you'd need either a dyno tune & chip, or a tweecer (and all that
learning), or the latest version of the AFM PMS which reportedly is lots
easier to use but doesn't have quite all the capability of the tweecer.
I recently read up on it a little and it does seem to have most of the
major bases covered. The PMS is just under $1,000.
Now, for a strictly budget setup, I've wondered about using a decent
magnetic pickup distributor with a CD box and getting the pip signal
the efi ecu needs to run the efi system from somewhere in that system -
if that's possible. Then you could at least easily tune in a decent advance
curve and would just have the fuel delivery side of the ecu to worry about.
with big enuf injectors and a matching MAF like the latest versions from
PMAS you should be pretty decent shape on that, not that a tune or tuner
device wouldn't pick up some addition power thru a closer matched tune.
MysteryMachine
1,835
Parkesburg, PA
Jan 24, 2008
  • Jan 24, 2008
I might be looking into something like this someday. I looked at a spyder intake a while back and a site that had the carb intakes with the inj bungs. I'll have to see if I can find the links for ya when I get home.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Looking for a high-res photo or scan of Rotunda EEC-IV Overlay #17 or #23
  • Smokinjoe 33
  • Jul 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2026
Praetorious
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
