EEC-IV gurus ?
Stealth coupe
53
New Jersey
Does anyone know why my leftside tailpipe blows more steam when warming
up then the right. Ive asked a good friend of mine the same question and he
smiled and sayed his does the same thing. And a friend of his does the
same . All cars are fox bodies with 5.0 liter engines. Is anyone out there
having the same symptom? I just replaced my headers with long tubes and
changed my header gaskets to copper stye and I noticed heat (blue) marks
in between the flanges on the left bank with same paint bubbling on the
primary tubes, but nothing exists on the right. So im thinking more heat in
the cylinders on the left bank, hence the leftside blowing steam. I wanted to
get a laser heat probe to check my headers for inconsistencies in temps
between left and right bank. Does anyone have any valuble info to add?
One side having a bias is normal, it has to do with the exaust pulsing pulling in an order that pulls more to one side, but none or little at all on the one side...??? Try putting a rag or something to cap off that one side that most of it flows from and see if it flows on the other side, and if you can feel any real backpressure. Very well could be a stopped up muffler, either from a broken baffle or object in the exaust system. A restriction would also lead to more heat. You could remove the catback and run just the midpipe and see if it does the same thing even without the catback system. Does your system have catalyist converters? You could hook a voltmeter to each o2 sensor and see if they have similar readings. It's hard to help without actually seeing the car.
Sorry, planned on writing more lastnight but was very tired. Anyway my reference to the EEC is because I figured this might be a ecu thing since many of my friends cars experienced the same . My car has borla muffs, straight thru design. Non cats. No restriction that im aware of. Brand new long tubes with an h pipe so.....
As Jason indicated, it could be an exhaust cadence or path of least resistance issue. I cant figure out how the computer has anything to do with it.
Matter of fact, the precise metering and monitoring of things with EFI make it less likely to be a tune issue than with a carbed set-up.
Just MHO.
Good luck.
