EFI checklist?
  • Thread starter Thread starter allcarfan
  • Start date Start date Dec 16, 2005
allcarfan
The Answer Man
2,458
North Atlanta
Dec 16, 2005
  • Dec 16, 2005
Checklist for EFI conversion, am I missing anything?
EFI upper/lower intake
EFI valve covers
Electric fuel pump with return
Fuel pressure regulator
fuel rails
injectors
computer and harness
o2 sensors, MAF sensor, tps, etc
Throttle body
Throttlebody cable
What all am I missing for the conversion?
red65
411
Ann Arbor, MI
Dec 16, 2005
  • Dec 16, 2005
Here are a few things that come to mind right away:
- Air filter and intake hose (lots of possibilities here, from stock box to K&N to whatever you can dream up)
- Export brace replacement (stock braces don't clear EFI upper intake on a '65-6 - maybe other years too)
- Fuel filter with fittings / clamps / etc
- EGR spacer / EGR valve / EGR position sensor
- Return location in fuel tank (I used an existing drain plug)
- Header tank (you'll probably want one eventually, but not necessary just to get it running)
- There are three main wiring harnesses:the main one that connects to the computer, which you've listed, a second one that connects that harness to the engine-mounted components (injectors, distributor, etc), and a third that connects to the under-engine stuff (O2 sensors and the like). You'll need all three, of course. There's a fourth one that connects the alternator if you're using the Fox body-style alternator.
- Ignition coil
- Lots of wire ties, solder, electrical tape and patience...
Hope that helps.
LMan
1,246
Mom's basement
Dec 16, 2005
  • Dec 16, 2005
in case you have not seen it already:
http://mustangsplus.com/tech/efi/
allcarfan
The Answer Man
2,458
North Atlanta
Dec 16, 2005
  • Dec 16, 2005
What is a header tank? I have never heard of this piece.
LMan
1,246
Mom's basement
Dec 16, 2005
  • Dec 16, 2005
Functions like a sump. Keeps fuel at the pickup regardless of fuel-tank level so the EFI pump does not run dry/gulp air.
stangman16
640
San Antonio, TX
Dec 17, 2005
  • Dec 17, 2005
I'm going to get one for my EFI conversion, from Glen. Looks great and I'm sure it's going to work perfectly for me. If you have any questions about it - I'm sure Glen would be more then happy to answer them for you, he's been a great help to me on my EFI conversion process.
http://users.ev1.net/~gbuzek/
you'd have to click on rosehill performance products on the left, then on header tank in main page section.
Just thought you'd like to see what it looks like, very nifty device.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Dec 17, 2005
  • Dec 17, 2005
I don't see the ECU mentioned on your list.
stangman16
640
San Antonio, TX
Dec 17, 2005
  • Dec 17, 2005
don't forget the inertia switch...
F
Fostang
1,400
Stockton, Ca
Dec 17, 2005
  • Dec 17, 2005
I knew you'd eventually dump the carb.
Tubo(2-bo)
279
Ft Walton Beach FL.
Dec 17, 2005
#10
  • Dec 17, 2005
  • #10
Hey Shane, we can talk EFI, when I visit Atlanta, over NewYears. How you doing after the wreck?
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
