efi conversion trouble
  • Thread starter Thread starter 67shelbygt
  • Start date Start date Oct 15, 2010
67shelbygt
  • Oct 15, 2010
HI all well i havea question i recently purchased a summit efi conversion harness... now the origional instructions were destroyed (also i purchased this kit second hand but unused) so i cant get a new copy of the instructions...but the kit was shipped with a install instruction kit from the ford svo install kit ive been told they are the same kit but in the instructions i have there is only one brown plug next to the self test plug and the harness actually has two a black and grey plug and the wiring on the green plug next to the computer has different wiring than the instructions suggest..to run the fuel pump etc now has anyone done this conversion and run into this problem..ive looked online and cant locate any diagrams of the black and grey plug setup only the brown one...and im quite certain that in my past experiences with fox cars all the ones i worked on had the dual plugs not the single...any ideas suggestions appreciated in advance
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Oct 15, 2010
  • Oct 15, 2010
The instructions for the Summit EFI Harness are available as a free download:
Summit Racing SUM-890120 - Summit Racing® EFI Wiring Harnesses for Ford - Overview - SummitRacing.com
67shelbygt
  • Oct 15, 2010
thanks for the reply...but now that i see their instructions i can see clearly that the harness i got certainly did not come from summit unless its an older version of the harness as the one i have is similar to the harness that ford racing origionally sold with the exception of the plugs i mentioned earlier which are the ones i need to cut into and connect to my car...through my research it looks like the harness that ford svo sold origionally was similar to an 89 mustang harness and the harness i have now is for a 91-93 car it is a new harness but i think the guy i bought it from is lying about where he got it from...any other suggestions...i guess what i could really use is the harness diagram for a 91-93 ecm harness that would likely help me figure out what colors i am actually looking for
Realmongo
2,466
86
99
Western Mass
Oct 16, 2010
  • Oct 16, 2010
You might be able to locate a '93 wiring diagram over in the Fox 5.0 section. Another website mustanggt.org has been posting a lot of technical information on those cars.
67shelbygt
  • Oct 16, 2010
thanks for the tip ill check that out
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
