EFI Parts
blown65
1,938
Queen Creek Arizona
Going carb so here is my take off parts. These have only been run a few times with 0 miles drivin on them. Its as new as new gets. Ill get pictures later. The Injectors however are used. Car ran with all this on, just decided to go a different direction.
36lb used injectors 125.00
80mm Pro-M with filter cal for 36lb injectors 150.00
Fuel Rails. (Steeda I believe) 75.00
Trick Flow Track Heat Upper and Lower w/new ACT and ECT sensors 325.00
92 Computer A9P I believe and modded factory harness 225.00
Tweecer RT 475.00 (only used a few times in tuning. works great)
Accufab TB w/spacer, w/new TPS and 2 IdleAir. IdleAir is modded for idle. (Ill check size, cant remember) 180.00
92 EFI dist with new module, cap, rotor. 100.00
Ill have some Hyd Roller Lifters and a Crane Hyd Roller cam FS soon also, just need to get the numbers off the cam. (Going Solid Roller).
Pictures to follow after I do a little cleanup. Just pulled the motor out.
