EFI throttle for 65
  • Thread starter Thread starter roan65
  • Start date Start date Dec 29, 2005
R
roan65
103
Wasilla Alaska
Dec 29, 2005
  • Dec 29, 2005
It sounds like I need a 69-70 gas peddle and then a late model cable. Is this correct? That will be a bolt in deal, and should be no fabing?
Living in Alaska finding a Mustang in a salvage yard is very rare!!! Where can I find a gas peddle and bracket for a 69-70?
Tubo(2-bo)
279
Ft Walton Beach FL.
Dec 29, 2005
  • Dec 29, 2005
The 69-70 works fine,with the fox body cable. I have one in my 65. Though actually just about any year, mustang cable actuating pedal will work, though each will require a little tweaking. Make sure to get full butterfly opening.
red65
411
Ann Arbor, MI
Dec 29, 2005
  • Dec 29, 2005
I used a Fox (87-93) pedal with cable, and attached it using the bracket built for that purpose - National parts depot sells them, among others. You might have an easier time finding a Fox-body pedal than a '69 one...
R
roan65
103
Wasilla Alaska
Dec 29, 2005
  • Dec 29, 2005
well I took red's advice and found a fox peddle and cable. Now I can't find the bracket! I calle NPD, Mustang Depot, and Sacramento Mustang, and nothing! I also searched Mustang Plus website with no luck either!
Anyone have a part number or no where to get the bracket? or once agian where to get a 69-70 peddle?
red65
411
Ann Arbor, MI
Dec 29, 2005
  • Dec 29, 2005
National Parts Depot's part number is 9725-10. Unfortunately, I think they source the part from Windsor-Fox, which has earned a bad reputation on this board for being less than reliable. I'm not sure by your note if NPD didn't have them, or if you just couldn't find them in the catalog.
Hope that helps - I feel bad for possibly leading you astray...
M
mustangracer
360
Southern California
Dec 29, 2005
  • Dec 29, 2005
I found that NPD did not have the bracket, and had no idea when or if they would get more. I ended up fabbing my own bracket similar to the W-F one.
R
roan65
103
Wasilla Alaska
Dec 29, 2005
  • Dec 29, 2005
I didn't give them that part number but the guy said he couldn't find anything like that in the computer. When taking to a fellow at Sacramento Mustang he told me that was a Windsor-fox item, and they have not answered any phone calls for about the past year.
What does the bracket do anyways?
red65
411
Ann Arbor, MI
Dec 30, 2005
  • Dec 30, 2005
The bracket just spaces the Fox accelerator pedal away from the floor, provides the correct mounting bolt pattern, and angles it appropriately for the '65's floor pan (back toward you more). mustangracer has it right - this would be an easy part to fabricate if you have access to basic shop tools, including a welder. I'm sure you could dream up a bolted assembly as well if welding is a problem. The only nice thing about the W-F part (I guess that's what it was) is that someone's already done the skull-work for you. Good luck!
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
