EFI wiring fuse?
  • Thread starter Thread starter stangman16
  • Start date Start date Nov 12, 2007
stangman16
640
San Antonio, TX
Nov 12, 2007
  • Nov 12, 2007
I don't have the EFI harness on any fuse so I need to get that fixed - is it only the power wire that needs to be fused that goes to the starter relay to draw its power? If so, what size fuse should I use? Would you suggest a blade style in-line fuse?
I'm confused on how to determine what size fuse to use for the gauge of wire..
mr_woodster
1,314
Riverside, CA
Nov 12, 2007
  • Nov 12, 2007
i just used the inline fuses from a 87-93 fox. They have the proper sizing and usually the same color coding if you used a factory harness. Wire gauge from what i have been seeing is 16gauge for always hots, according to the wiring diagram i have.
I'm sure someone will chime in on the specs for the fuses.
stangman16
640
San Antonio, TX
Nov 12, 2007
  • Nov 12, 2007
Looks like I have a 10gauge wire for power going to the starter relay + connection. I'm going to have to go to the parts store to get an inline fuse since I don't have time to go out to the salvage yard. How do I know which blade fuse to get though? (for amps, etc.)
Tim65GT
1,149
West Texas
Nov 12, 2007
  • Nov 12, 2007
Lots of good info here:
http://fordfuelinjection.com/files/EFI_power_diagram.gif
and here:
http://fordfuelinjection.com/?p=8
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
