SJB Parasitic Draw, Fuse 59&67
2005 Mustang V6
CA
I have a parasitic draw and I pin pointed to SJB fuses 67 & 59. 67 draws more amp than 59 and they fluctuates. seems like switch is turning on/off.
There are posts about this exact fuses having draw, but none of the forum comes to a conclusion on a fix. I looked into it and the compromised SJB could draw the amps, I cleaned and sealed off all water intrusion points and changed SJB to other working one. The previous SJB had constantly on headlights and i switched it to salvaged SJB and it worked. I also heard the CD exchanger could draw the amp so i took it out the console. if SJB is the problem, im thinking of installing a kill battery switch.
Was anyone out there solved this problem?
Asking Gemini, it says fuse 67 and 59 are sjb and could be centor console waking up. I do have the driver door adjar signal going off and that could cause the system to wake up thinking the doors open. Thanks for your input.
View: https://www.youtube.com/shorts/4IBBLKJcpNI
