  • 1994 - 1995 Specific Tech
egr question
  • Thread starter Thread starter legalize420
  • Start date Start date Jul 14, 2005
legalize420
1,541
South Florida
Jul 14, 2005
  • Jul 14, 2005
will the check engine light come on if i get rid of the tube and cap off the ends.
CManT1914
3,172
Killeen, Texas
Jul 14, 2005
  • Jul 14, 2005
Not as long as you push the plunger halfway down and secure it.
legalize420
1,541
South Florida
Jul 14, 2005
  • Jul 14, 2005
how do you secure it?
CManT1914
3,172
Killeen, Texas
Jul 14, 2005
  • Jul 14, 2005
Anyway really. I've seen guys use wire ties, plastic caps and stuff. I just taped mine haflway down until I can find something better to secure it with.
mootang
907
texas
Jul 14, 2005
  • Jul 14, 2005
no just cap off your header and leave the egr open. thats how mine is and it never set the check engine light off. also i never pushed the plunger in.
94-302-vert
1,947
NE CT
Jul 14, 2005
  • Jul 14, 2005
FYI, I depressed the plunger with a yellow wire nut pressed onto the sensor with a vise, then I secured that with a hose clamp.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jul 15, 2005
  • Jul 15, 2005
there is absolutely no performance gain from removing the egr valve. the only reason i did it was to clean up the engine bay some. if you are leaving the sensor bolted to the intake elbow and only capping off the tube, i would just leave it alone.
legalize420
1,541
South Florida
Jul 15, 2005
  • Jul 15, 2005
i am not doing it for the performance. my tube was leaking and i even tried getting a new tube but still no luck. i capped it off last night and so far the driveability is much better. can you elaborate a little bit on your last sentence. what do you mean by leave it alone.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jul 15, 2005
  • Jul 15, 2005
well, being that there was a problem with the tube, that makes it a whole other story. as far as leaving it alone, the egr is completely closed at WOT. the only time it does anything is at part throttle which is why i said there is absolutely no perfromance increase by removing it. the only correct way to remove the egr is to completely remove the entire thing from the intake elbow, use a blockoff plate on the elbow, cap the header, and remove the egr system in the eec with a tweecer , pms, or custom chip.
18mustangs
533
Virginia Beach, VA
Jul 15, 2005
#10
  • Jul 15, 2005
  • #10
Yep, a 5\8" flare nut on the EGR from Home Depot will do just nicely, no need to push the plunger in on mine either.
C
chrisilversvt
66
memphis,tn.
Jul 16, 2005
#11
  • Jul 16, 2005
  • #11
so does anyone have a how to with pics. or a link to a how to w/pics....on how to do this to the plunger?????
legalize420
1,541
South Florida
Jul 16, 2005
#12
  • Jul 16, 2005
  • #12
i did not secure the plunger and so far no CEL
18mustangs
533
Virginia Beach, VA
Jul 16, 2005
#13
  • Jul 16, 2005
  • #13
I didn't secure the plunger either. I put Fox LT headers on so all I did was screw on the 5\8" flare nut from Home Depot onto the EGR valve, and I've never had the dreaded CEL either. That being said you should only disconnect your EGR if you've shut the EGR off inside of the computer with a tuner (I didn't do this and am putting a Fox EGR setup on now), otherwise your computer is still adding a lot of timing to compensate for the exhaust gases that should be present. This could lead to the ping thing. My 2 cents.
(Pic courtesy of Rio5.0)
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
