  • SN95 4.6L Mustang Tech
egr tube...
  • Thread starter Thread starter myg-
  • Start date Start date Nov 21, 2006
M
myg-
71
  • Nov 21, 2006
lets say i just broke my egr tube.. with a hole the size half of a dime.. will it be a huge exhaust leak? or uhm.. yeah how can i fix that ^_~
R.J.
813
Warwick, Rhode Island
Nov 21, 2006
  • Nov 21, 2006
Napa sells high temp rubber hose (it is green). there are some companies who supply this green hose when there parts require a modification of the tube. i.e. intake spacers, aftermarket intakes, superchargers...... As long as it is not to close to the header it will be fine.
M
myg-
71
  • Nov 21, 2006
can i just rip off the egr tubing from the exhaust manifold up to tmy engine bay and cap it off (on the exhaust manifold) with a bull plug?
mustangman9812
661
Mars Hill, NC
Nov 21, 2006
  • Nov 21, 2006
yeh
jstreet0204
939
Winston Salem, NC
Nov 21, 2006
  • Nov 21, 2006
You can take the egr off, but without turning it off in the eec you are going to have two issues.
You are going to get a check engine light, and the bigger issue is that the eec adds alot of timing when it thinks the egr valve is open. If it thinks it is open, but not actually flowing you will likely get some pinging or bucking under part throttle.
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
  • Gulftown980x
  • Jul 29, 2026
squeak93
No volt reference?
  • Creomod
  • Aug 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 14, 2026
Creomod
D
Ford AOD Transmission filler tube orings
  • Dagasser
  • Jul 21, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 26, 2026
