EGR Valve Eliminator Kit
Michael Yount said:
www.ronmorrisperformance.com
However - you may be better off using something to modify the ecu and turn off the egr function in the computer when you remove it. Requires a chip, pms, tweecer, etc. to do so.
Good site Micheal. I went to the specail parts section. It has thermactor and canister purge eliminator kits as well as the EGR kits. Even little things like canister purge and thremactor missing tells the computer something is wrong, and it is programmed to compensate. Even a non-drivability issue through the computer can become one. Maby I should just break down and get a tweecer or a whole stand-alone unit.
