eibach lowering springs
Would i have to buy the camber plates if i lover my 02 gt with the Eiback lowering springs? i really dont want to mess with that. And also, im about to order the Pypes exhaust X-Pipe. how hard is it to do compared to other brands? any complications? any info would be great.!
If your choice of Eibach springs is the pro-kit. Your alignment will not even change, and no you will not need caster/camber plates. However if you choose the sport-line set . This changes ones thinking. The sport-lines drop is excessive for a every day driver. This will create a need perhaps for caster/camber plates,to provide the needed alignment to stop from destroying tires.
It depends on the car. I have a pro kit and they ARE NEEDED. Sportlines on an 04 I had they were needed too. I know others who have not needed them at all and have perfect alignments. I don't have that good of luck.
You can slot your bottom holes on your struts for a bit more adjustment if your just barely off and don't want to pony up for the cc plates. Or just buy them and be done with it.
cater/camber plates are a good safeguard, if you're going to go with any i'd recommend the maximum motorsports version, they really help from having uneven wear on your tires (tires aren't cheap an a bad alignment isn't safe)
NOTE: i have a set of eibach pro kit springs for sale for cheap if you want them, brand new... PM me
mods feel free to ban me :nice:
