Eldelbrock Performer Intake Question
  • Thread starter Thread starter smitty194
  • Start date Start date Jul 13, 2012
smitty194
15
  • Jul 13, 2012
Car is 93 coupe , but motor is explorer 5.0 motor , will intake designed to fit mustang 5.0 motor fit explorer motor ?
YLWSTANG
42
Mass
Jul 13, 2012
  • Jul 13, 2012
yes it will
smitty194
15
  • Jul 13, 2012
K thanks found a good deal on intake 70mm throttle body an maf 24lb injectors , fuelrails an fuel pump
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 13, 2012
  • Jul 13, 2012
That makes a good start. pretty much the explorer engine is the same.
smitty194
15
  • Jul 13, 2012
Maf is a c&l . Wat you recommend
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 13, 2012
  • Jul 13, 2012
Throw it away and get any other brand... I have a C&L it causes issues like not reading correctly. Are you planning on running the Factory Airbox? Cuz if you run any other "CAI" even though its tuned for a "CAI" it will cause a higher reading at idle and crusing. Aftermarket CAI like my BBK have mandrel bent tubing and this causes a higher velocity in the air stream which in turn causes the C&L meter to read high. Trust me i went through this already, I talked to C&L and a number of shops about this issue. SO do yourself a favor im going to get a Pro M.
smitty194
15
  • Jul 14, 2012
Will I need a bigger fuel pump for 24lb injectors 70 mm tb, 73maf
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 14, 2012
  • Jul 14, 2012
Yes a 155lph will work perfect for that setup. If it is a street car the C&L is junk if you just race it you might get away with it.
Reactions: 88LX5.Oh
YLWSTANG
42
Mass
Jul 14, 2012
  • Jul 14, 2012
I've been using my C&L for 13 years never had an issue. However it does seem like alot of people do have problems with them. MAF russian roulette.
smitty194
15
#10
  • Jul 14, 2012
  • #10
Yea its a street car but it sees the strip once or twice a month , thanks for the help guys
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 14, 2012
#11
  • Jul 14, 2012
  • #11
Yup just try it out you might get lucky, What kind of setup are you running? Filter on MAF or CAI or Stock airbox
smitty194
15
#12
  • Jul 14, 2012
  • #12
Cai
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 14, 2012
#13
  • Jul 14, 2012
  • #13
Ok you may need to lower your fuel pressure some. First get the thing together and see how she does, mine was running slightly rich due to the fact that the CAI tube produces a higher intake velocity which causes the maf to read as if there is more air than the engine is actually ingesting. Lowering the fuel pressure by 1 lbs evened mine out for driveability, i have an a/f gauge to keep an eye on what its doing.
But that was the case with mine. you may not have the same issue i had. If you want everything to really work together well you can send the unit with your sensor installed and your CAI to C&L for $25 they will get you the proper sample tube installed. What they do is set the housing up with YOUR CAI and sensor then they "dyno" the setup and cut you a new tube that calibrates the entire unit to your injector size.
It is a hassle but if you already have the C&L this will get it all working properly.
stykthyn
5,232
2,652
223
gainesville
Jul 14, 2012
#14
  • Jul 14, 2012
  • #14
I ran an eddy performer on an explorer longblock with a stock HO cam. it ran like a beast.
Explorer intake vacuum port
  • JD1964
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 29, 2026
Mustang5L5
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
