electric fan
  • Thread starter Thread starter enferno
  • Start date Start date Sep 19, 2006
enferno
418
  • Sep 19, 2006
a buddy of mine gave me an 11" tripac electric fan.
it already has a relay, but what else do i need to get this thing to work?
thanks!
LazerStang760
97
California
Sep 19, 2006
  • Sep 19, 2006
I wouldn't use it if I were you, unless you plan on using two fans. I don't think you want to use anything smaller than a 14 when using a single fan.
enferno
418
  • Sep 19, 2006
that's why i am going to try it out.
it was free, so what do i have to lose?
Cannoball888
320
Gainesville, FL
Sep 20, 2006
  • Sep 20, 2006
I heard tripac were the worst fans made.
67Dylan
259
Phoenix, AZ
Sep 20, 2006
  • Sep 20, 2006
That's a loaded question. Just to power it on you do have nothing to lose, but if you want to put it on your car then IMO you could have a lot to lose if it can't cool your car properly.
If you want to see if it works you can hook it up straight to the battery and watch your fingers. There, it works... What size fan is it? Does it have the fan shroud as well? Do you know how to hook up a realy or is that where you need help?
Spoofty
61
  • Sep 20, 2006
11" does sound small for one fan. I'm running 2 12's.
Vinyl66
398
  • Sep 20, 2006
Try it to see if it works then sell it and get a good 16" fan. I have a SPAL and it works great.
enferno
418
  • Sep 20, 2006
still haven't really answered my question . .
let me clarify more i guess
what else do i need electrically?
just wire it up and throw a switch on it? what about a thermostat etc.
obviously if the car overheats i will not use this fan, but because it was free i might as well throw it in just on the chance that it will sufficiently cool my car.
jcode68
892
Massachussetts
Sep 20, 2006
  • Sep 20, 2006
Since you already have the relay, all you need is a switch. You could go thermostatic switch, which turns the fan on at a given temp and mounts in either a coolant passage (thermostat housing is where I have mine) or I have also seen thermostat probes mounted thru the radiator. You could always put a flip switch on it and control it manually as well. Definately a low cost temp solution to determine if you want to keep the thing.
enferno
418
#10
  • Sep 20, 2006
  • #10
what are the benifits for a switch versus a thermostatic switch?
jcode68
892
Massachussetts
Sep 20, 2006
#11
  • Sep 20, 2006
  • #11
A flip switch is cheap ($2 bucks at Radio Shack), readily available and easy to install (simple wire hookup versus plumbing involved). This would allow you to evaluate the fan without spending too much time or money to do it.
enferno
418
#12
  • Sep 20, 2006
  • #12
cool thanks.
in the long run thoug, should the fan work, what is the benifit of a thermostat vs. switch? just the fact that i wouldn't have to turn it on/off myself?
jcode68
892
Massachussetts
Sep 20, 2006
#13
  • Sep 20, 2006
  • #13
enferno said:
cool thanks.
Correct. When the temp reaches the temp that the switch is designed for (say 185 degrees), the fan comes on and stays on until the temp falls below. My guess is you will be running pretty hot if not overheat with a single 11 inch fan as others have suggested.
enferno
418
#14
  • Sep 20, 2006
  • #14
one last thing - wire the fan to suck air through the grille correte?
jcode68
892
Massachussetts
Sep 20, 2006
#15
  • Sep 20, 2006
  • #15
Assuming it's a "puller" type fan, then yes, wire it to pull air.
67Dylan
259
Phoenix, AZ
Sep 20, 2006
#16
  • Sep 20, 2006
  • #16
One more thing: wire the switch thru the relay NOT directly to the fan. If you wired it to the fan and the current rating is not w/in parameters.... watch out.
Do you know how to wire the relay?
enferno
418
#17
  • Sep 20, 2006
  • #17
i have a basic understanding how.
prong 3 to the battery, 5 to the fan. 1 to the switch, and 2 to the ground
correct?
if you have any tips i'd appreciate it though!
enferno
418
#18
  • Sep 20, 2006
  • #18
is a 65 amp alternator going to be enough to run the fan?
i'm not running a big stereo, just 80 watt.
stock headlights etc.
67Dylan
259
Phoenix, AZ
Sep 21, 2006
#19
  • Sep 21, 2006
  • #19
You should be fine w/the stock alt.
As to your wiring of the relay... sorry I'm not familiar w/the number system you described. I know the standard bosch numbering (85,86,87,&30)... easy enough to help if you really need it tho.
chepsk8
2,203
Easton, PA
Sep 21, 2006
#20
  • Sep 21, 2006
  • #20
Fan wiring
I run a 16" fan, use a relay, and got a temp sensor from Painless. I drilled & tapped the hole in the thermostat housing, and located it there. Fully automatic, works perfectly.
I also did that back on the DCVER as well, back in 1986, used a sensor from a BMW....
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Who Is Up To Date On DCC Fan Controllers?
  • BoostedRed89gt
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2026
revhead347
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
W
2.3l cooling fan questions
  • waxman
  • Jun 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2026
AeroCoupe
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
