I've been helping a friend swap a carb'd 351W into his 1989 mustang. This was originally a mass air car, I got the EFI stuff as payment....
. I checked out Jason Fletchers site, which helped me solve the spark problem, but I'm now having a problem with the turn signal lights and the brake dummy lights are staying on in the instrument gauges when the headlights are turned on. I just read the website today and haven't had a chance to jumper the two connectors on the harness by the brake booster, nor did I remove the EEC power relay, could this be causing the problem? I also noticed that the parking lights stay on when the ignition is turned off, and the headlight switch is off. When I jiggled the starter solenoid they would flicker on and off.. Any ideas
